Question about Tomtom ONE GPS Receiver
Reformat sd card for tomtom one
What do you mean you went to computer and reformated the sd card...how do you do that?
  • 321help Jun 05, 2008
    what do you mean you went to computer and reformated the sd card...how do you do that?
    Novelist:
  • 158 Answers
FIRST THING , Backup the SD card. To format an SD card you insert SD card into card reader slot on a PC or a SD card reader. Then find the SD card Icon in 'my computer'. Then hover over it with the mouse and right click , choose 'format' from that drop-down menue. REMEMBER .... EVERYTHING ON THE CARD WILL BE DELETED ! *** WARNING *** The card will not work in the tomtom once it has been formatted.
Posted on Jun 12, 2008
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
I reformated my canada xl 310.i lost all my files.just a screen with a red x.
You've probably backed up the contents of your TomTom disk (when it was connected to your computer) to your computer before you reformatted the TomTom Disk. Or you used the TomTom Home to back up the contents of your TomTom.
Try to copy the back-up files back on to your TomTom device disk and see if it works.
Just curious ... why did you reformat your TomTom disk ? which will erase all the files on the TomTom disk.
Jan 25, 2014 | Tomtom XL GPS
Tomtom shows a red cross over the SIM card and will not turn on.
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Apr 23, 2010 | Tomtom ONE GPS Receiver
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
Tomtom One 3rd Edition will show green light but will not turn on
If you have an SD card in then remove it and try to boot it up.
It is possible that the SD card is corrupt or faulty.
If it does not power up with no SD card then it may well need to go in for repair.
Should you get it to boot without the SD card then back it up straight away.
Reformat your card (preferably in a card reader) and then restore to the card . You should then be able to put the card back in
Aug 20, 2009 | GPS
Reformating
what kind of phone is it, my phone came with a mini-sd card adapter. just get an adapter and connect to computer to format.
Mar 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
Reformating card
I deleted TomTom Home from my computer. I downloaded a version of Home just for Mac OS 10.4 users and rebooted. Then I followed the directions and it downloaded all of my maps, etc to the original TT SD card. I also set up my cell phone with a bluetooth connection.
Didn't need to reformat the new SD card I had bought because the original card had enough room for everything.
Thank you for asking.
Jul 12, 2008 | Tomtom GO 510 GPS Receiver
Reformating card
i don't think tomtom supports SDHC cards you will need a non SDHC card try here
memorybits.co.uk
Jun 09, 2008 | Tomtom ONE GPS Receiver
Reformating a micro sd card
i would like to know how are you formating the phone
is it through the blue tooth
or by optical fiber cable connection.
Jan 03, 2008 | Samsung SGH-E900 Cellular Phone
Tomtom ONE GPS Receiver Logo
867 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
