Question about Sony PlayStation 2 Slimline Console
PS2 Power problem
I took my PS2 Slim apart to clean it out, put it back together and now there is no power getting to it. It was working fine before and I have taken it apart numerous times before for cleaning. I have replaced the power button with no luck. What do I check now?
  • wingnut3 Nov 27, 2008
    i recently took my playstation 2 apart to clean my lense and i was just following instructions from youtube! but when i put it back together there was no pwer could you please help as it is actually not my playstation but my sisters boyfriend! get back to me as soon as possible! mine is the fatter of the playstation 2! please and thankyou
Sds
Posted on Nov 29, 2008
    Scholar:
  • 65 Answers
Check the power supply.Use a multimeter if you have any voltage coming out from the power supply.
If the power supply is good Check the main fuse on the motherboard.There is a white ceramic fuse on the motherboard and sometimes get Bad.
Good Luck
Posted on Jun 19, 2008
My ps2 is the thicker one, it has quit readung dvds and allbut 3 of my ps2 games,it won't even read a laser lens cleaner
Hi, this happened to me once. What i did was remove the top cover of the ps2, carefully removed the power button from the cover, i removed the cover from the lens and i carefully cleaned it manually with a cloth... then put it together just like you took it apart, worked great for me
Dec 24, 2010 | Sony PlayStation 2 (PS2) Console
I took my PS2 apart to clean the lense becaus it wasn't reading discs properly and when I put it back together I got nothing. No red light, no green light, no power whatsoever! Please help!
be sure that the wire that connects to the power buttons are property installed, also to the playstation, , be really careful.. also what you can do is just give them a small push to both of them to make sure they are getting a connection
Dec 22, 2010 | Sony PlayStation 2 (PS2) Console
Cant put unit back together
You can go to the manufacturers website and download everything you will need. Their tech literature is pretty extensive.
http://www.mrslim.com/customerCare/resources.asp
Apr 03, 2009 | Heating & Cooling
Ps2 slim scph-75001 starts to read the games but then stops!
your lense is more than likely defragmented jacob and you should never take any system apart okay so what you wanna do is if your warrenty is still in effect dont tell sony you took it apart just send it in for a refurbisment if it isnt you need to look around online for a ps2 slim lense okay
Mar 08, 2009 | Sony PlayStation 2 (PS2) Console
Broken
hi there there are loads of videos on you tube that shows you how to put this back together make sure you look up the right ps2 ie ps2 or ps2 slim they both open and come apart completely different
hope this helps ya a little
Feb 06, 2009 | Sony PlayStation 2 (PS2) Console
Disk tray opens and closes repeatedly
WHEN IT OPENZ PUT THE DISK IN ND IMMEDIATLY TAKE THE POWER PLUG OF WAIT A SEC ... RE PLUG ... RESTART THE SYSTEM AND OFF YOU GOOOOOO
Jan 18, 2009 | Sony PlayStation 2 (PS2) Console
It has no power to playstation
thats a ver delicate part ,you have to be sure thats connected straight down to the PC connector , its kind of hard cause theres no much space to work on , hope it helps
Apr 23, 2008 | Sony PlayStation 2 (PS2) Console
Won't read disc.
Hi Crashley41 and Von281,
Since you have the bid Phat mode; you will have better luck at fixing your PS2.
This is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you still have trouble reading discs. Click on " Repair Directory" at the bottom of this screen. Then on the next page click on "Video Game Consoles". Pick a Repair shop to get your PS2 repaired. Fixya has some good ones dedicated to Playstations.
Nov 23, 2007 | Sony PlayStation 2 Slimline Console
Ps2 not working
He forgot to plug up the power cord inside.
Nov 18, 2007 | Sony PlayStation 2 (PS2) Console
Cdrom won't spin
HI THIS PROBLEM IS USUALY CAUSED WHEN LID IS PUT BACK ON .. THERE IS SOME LITTLE SWITCHERS ON THE PS2 NEAR THE LASER THESE SWITCHERS ARE TO TELL PS2 WHEN LID AS BEEN OPENED AND A ANTI PIRACY PROTECTION FOR DISK SWOPPING PICS SHOW WERE THE LITTLE SWITCHERS ARE ..__TRY TAKING THE LID BACK OFF AND PLACING LID BACK ON WITH LID TRAY SHUT AND IF THAT DOES NOT WORK CLOSE WITH LID OPEN AND AT THE FRONT WERE YOU PRESS THE BUTTON TO TURN POWER ON CHECK IF THE LITTLE SWITCH AS COME AWAY OR BROKE IF SO I SELL REPLACMENTS MY WEBSITE IS WWW.CONSOLEREPAIRANDPLAY.CO.UK
May 23, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
184 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
