Gateway m series wont power on, is plugged up, pulled and reinstalled battery...
  • rxip Aug 15, 2008
    I have the Gateway M-6750
    I put a cd into the laptop and not a second passed after it closed that the laptop just powered down and it was charging and it was charged before it powered down. I doubt it was the cd because i bought it from best buy and it was to help me transfer my music.
    Now the laptop wont even power... and its been charging for over an hour.
I am having the same problem. I tighten the screws in the bottom and it started working. I am not sure for how long.
Posted on Aug 04, 2008
    Problem Solver:
  • 31 Answers
Change the internal power.
Posted on Jun 05, 2008
Turn it on and light comes on but it blinks like 5 times after that it shuts down, each time i tried it did the same thing
take the battery out and unplug it wait a while then reinstall battery make sure your plug fully engages and no excessive wobble may also take a electric test meter and check out put voltage on power supply could have broken wire or shorted out or some one oopsed then forgot to tell you ie dropped it or pulled little plug out n dropped it in the dogs water pan whilst still plugged into wall socket as I have done if you can load test batteries as well as continuity might be bad batteries even new stuff can fail upon use the blink is a no power input/ dead battery signal you can try swapping batteries if another one is accessable if not 1800 gateway or gateway.com ask an indian if still under warrenty use it you payed for it also can power it up usb to usb with a lil engineering I think????????????????
Mar 31, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
How to replace a video cable
In a Gateway M-7351u Notebook PC?
1) http://www.insidemylaptop.com/replace-broken-lcd-screen-gateway-m-series-laptop/
2) http://www.insidemylaptop.com/replace-keyboard-gateway-m-series-notebook/
Motherboard side of video cable, should be under the Switch Cover, (LED indicators, Power On button, speakers, etc), or under the Keyboard close to the Switch Cover.
Don't forget to remove ALL power. Remove the AC adapter (Charger), and Battery. (Use CARE. Wires going to Switch Cover. Do not cut them by accident, or pull on them when removing Switch Cover )
http://www.ebay.com/itm/GATEWAY-MC7310U-MD2614U-LCD-VIDEO-CABLE-DD0AJ2LC000-/390069940144
Regards,
joecoolvette
Oct 24, 2012 | Gateway M-7351u Notebook
I have a gateway mp8708 and it wont charge, boot, or even power the charging led. i tested the charger and itd fine. what could be the problem?
One of two things are likely your problem:
1) The battery is so dead that it's preventing any power from reaching the rest of the PC. Try pulling the battery out, plugging the laptop in, and turning it on.
If that doesn't work,
2) The motherboard power converter is burned out. If this is the case, unfortunately you will need a replacement motherboard or a replacement laptop.
Good luck, and hope this is helpful!
May 18, 2011 | Gateway MP8708 Notebook
Have a Gateway NV78 Laptop love it but there are 2 blue lights on lower left corner of the laptop and the one on the right goes to "red" sometimes why? This is "on the case" not the screen/monitor...
Do you have the Gateway NV78 Series User's Reference Guide?
(English)
Gateway Support > NV78 Gateway NV78 Notebook Series > Support Documents,
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78ul.shtml
If not, left-click on,
Gateway NV78 Series User's Reference Guide - English
This is a PDF file.
Takes a few seconds before you see the first page, and additional time to fully download.
Suggestion is that you let the file fully download, before looking through it.
(Your computer has Adobe Reader on it, which uses PDF files)
Page 18,
Battery Charge Indicator.
(Has a symbol which looks like a flashlight battery)
"LED Solid Red
Battery is malfunctioning
Important: This LED only lights up when your notebook is connected to AC power, (The AC adapter is plugged in. 'Charger'),
or the battery charge is very low"
Jul 03, 2010 | Computers & Internet
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Gateway computer 310 series wont power up when
It sounds to me like the power switch is plugged into the motherboard incorrectly. I would need to know the type of motherboard you have to get you the proper schematic for hooking up the power switch and reset switch to the board. If you have the manual to the motherboard, there should be a detailed picture showing you how it is to be hooked up. Please let me know the motherboard model for further assistance.
Good Luck,
NOLA Tech
Jan 29, 2010 | Gateway 310 S PC Desktop
M-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Aug 24, 2009 | Gateway Computers & Internet
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Computers & Internet Logo
847 people viewed this question
David Payne
David Payne
