Question about Pioneer AVIC-Z2 Car DVD Player
Pioneer avh p4000dvd w/GMOS-04 wiring harness
I have a 2005 H2 w onstar and the Bose system. I am installing the pioneer avh p4000dvd. I bought the GMOS-04 with the radio to install with my factory system. I had everything wired up as the instructions showed. For about ten minutes the radio worked fine, then all the speaker except the drivers front quit working. After rechecking all the connections I came to the conclusion that the Metra GMOS-04 harness was bad. I took the harness back and got a new one. After hooking up the second metra harness the exact same thing happened. All the speakers except the drivers front quit working after about an hour.
Anyone with any anwsers to this mistery would be a great help. Thanks
  • Doug Babb Jun 05, 2008
    It worked if both times before I turned the key off. I noticed the problem after turning the key back on both times.
    Not sure of the guage of wire. Its just the harness off the Pioneer unit to the Metra GM plug I bought for the factory intergration. I am not hooking up anything extra, just the pioneer head unit.
    Genius:
  • 2,035 Answers
This seems the setting change in the player set to factory setting and then see if you face the same problem please use this
Pioneer avh p4000dvd w/GMOS-04 wiring harness - moz-screenshot.jpgmoz-screenshot-1.jpg For Service & Support Please ContactPioneer avh p4000dvd w/GMOS-04 wiring harness - 310397382support-icon_small.jpgi.fixya.net/uploads/images/310397382support-icon_small.jpg" alt="310397382support-icon_small.jpg" class="h_mi" /> 1925 E. Dominguez St.
Long Beach, CA 90810
Call (800) 421-1404
Or contact us by
e-mail.
Hours of operation:
24 hours a day for most services. Hours for product service, product operation and parts inquires:
Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern (plasma, DVD rec
Posted on Jun 05, 2008
  • 3,037 Answers
I think you need a different harness, this one isn't handling the power I believe. What are the wire gauges
  • Benjamin Patri
    Benjamin Patri Jun 05, 2008
    Well I would first try a different unit with the same harness and if it happens again, see if you can get a better harness. Also check with the place where you got it from what they would advise instead of the current harness as they should be able to tell you what gauge wire you have and what should work otherwise. Let me know if you need anything else
    President:
  • 2,712 Answers
Are you doing anything specific when the audio disappears, or the speakers stop working all of a sudden, and altogether (except the drivers, of course)?
GMOS-04 wiring kit for 2005 YUKON DENALI XL
You need to talk to the experts on auto sound issues like this one.
www.crutchfield.com
Jul 05, 2016 | 2005 GMC Yukon Denali
I have a bad wineing noise when my 02 dodge ram 1500 is running after i installed a pioneer avh-p4000dvd and a 4 channel amp try to fix the problem
The noise is due to AC ripples in the power supply and so you will need to soften the power supply with the use of a isolated regulation or use of inductor/capacitor filters on the alternator circuit and the power supply to the system.
In most systems there are filters but if the alternator has isssues- power regulator or rectifiers- then the noise can be evident.
Please check with all the ground connecctions, check battery ground and the grounding of the set. You can try with adding a 0.5mfd/250V capacitor to the alternator circuit to be grounded.
Finally check the power amp. ground, use a direct line from the battery with a fuse and avoid the source from the wiring harness.
Oct 08, 2011 | Pioneer AVH-P4000DVD Monitor
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I bought a pioneer avic-x710bt navigation unit for my 04 suburban but I need some sort of adapters for the bose system and the onstar system can you tell me where I can get nessecary componets to install...
try a large retail store like best buy....give them all the info on the system u have a they may have the wiring harness u need to plug ur system in...if not call pioneer an ask for a install kit for the system
Jul 14, 2011 | 2004 Chevrolet Suburban
Brakes don't work after installation of pioneer
That does not make much sense. The brakes are not electric. What exactly is the problem?
Jul 03, 2011 | 2005 Nissan Xterra
I need a avh-p4000dvd wiring diagram
i have the manual for it .. i hope this helps -- ther are phone numbers to call Pioneer to get further information
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-P4000DVD_OperationManual0123.pdf
Oct 30, 2010 | Pioneer AVH-P4000DVD Monitor
I HAVE A F900BT WILL IT FIT IN MY 2010 CHEVY TRAVERSE? AND IS IT ALL PLUG & PLAY
It will fit, but the parts are expensive and it is not plug and play.
Parts needed:
Dash kit- Metra 99-3305 About $15-$20
Antenna adapter- Metra 40-CR10 (Chrysler antenna adapter) Yes GM uses Chrysler parts. About $10-$15
Wire harness/Interface- GMOS-LAN-01 (non bose or onstar) About $100
GMOS-LAN-02 (bose/onstar) About $120
The reason for the pricey harness is to retain data features on the vehicle and to interface with Onstar (GMOS02).
This is the right way so don't cut corners because it can cause issues on your brand new vehicle.
All of your safety chimes run through the stereo and not using the correct interface can cause issues with your gauges
www.metraonline.com or www.scosche.com are good sources for install parts info
May 14, 2010 | Pioneer AVIC-F900BT Car GPS Receiver
What's the recommended camera for avh-p4000dvd pioneer unit
Pioneer recommends Pioneer ND-BC2, but you should be able to use any with a descent viewing angle and RCA connections.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Pioneer AVIC-Z2 Car DVD Player Logo
1,407 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
