Question about LG L1004R Air Conditioner
Circut breakers My air unit keeps tripping out the circuit breaker. What should I do
  • Anonymous Mar 26, 2014
    MODEL# 30RAN010-055
    I have error code T200, where is the circut breaker to reset to allow the unit to start up?
    Problem Solver:
  • 18 Answers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Posted on Jun 05, 2008
At times it starts and runs fine.Then at times it starts and stops because the circut breaker in my house has been tripped.
Check the amp rating on the circuit breaker. It's probably 15 amps. Find another line with a 20 amp breaker, and see if it still trips.
May 31, 2015 | Air Tools & Compressors
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
Generator circuit breaker keeps tripping
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Dec 21, 2012 | Buffalo Tools Pro-series 7000 Watt Silent...
Largest circut breaker allowed on a residential heat pump
Sounds like the breaker is doing it's job. Stopping an over amping condition. You need to find out what the breaker is feeding power to. If it is the outdoor unit or the indoor unit. Also, the wire used has to be sized to the breaker otherwise, it will burn inside the walls and start a fire! Both the indoor and outdoor units should have tags or lables stating what the required amount of power is required. Better not let them do anything else untill you get more info. Sounds very dangerous to me but, I'm not there seeing what's going on.
Hope this helps!
Feb 06, 2010 | Ruud UAKA060 Air Conditioner
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
Circuit Breaker Tripping
either the circut breaker is getting weak,or the compressor is pulling to much power .
Aug 16, 2009 | Heating & Cooling
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Aug 01, 2009 | Amana PTH123B25AJ Heat Pump Air...
My dehumidifier keeps blowing the circuit breaker. It has never done this before - 3 years.
As the unit gets older the motor will cause more load on the circut, also after years of use the breaker will trip easier. Replace the breaker and you may get more use out of the unit but most likely you will have to replace the unit.
Jul 14, 2009 | Ebac HD880 Dehumidifier
Circut Breaker trips
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Jul 08, 2008 | Dometic NDR 1292 Refrigerator
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
LG L1004R Air Conditioner Logo
377 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
