Question about Rolex Day-Date President 118238 Wristwatch
Rolex crown problem
Hi Champs,
I have one Rolex Datejust (middle-sized, steel, white bezel with roman numerals), and I have a problem. When I unscrew the crown I can set the date in the mid position perfectly, but when I pull out the crown in full to the second position, I'm able to adjust time only counterclockwise. When I'm gonna do it clockwise, it sounds like a friction between pinions, and the hands doesn't advance, or they do it with an uneven and jerky motion.
I have my own working table, with a lot of fine tools from Witschi, Bergeon, etc., and I normally carry all of my watches' support and maintenance, but before dismantling the watch, I prefer to listen to your opinion.
Thanks in advace for your help, and receive my best regards from Madrid, Spain.
My email is jngpro@gmail.com, and my name is Jesus N. Gomez. I have a Doctorate in Electronic Engineering, and I'm 50 now. If I can be of any help to you, please let me know.
  • Jesus N. Gomez
    Jesus N. Gomez Jun 30, 2008
    Thanxs repman!
    I'll look inside thru the microscope, and maybe I'll be able to tell you more about it. Maybe I can post a pic with the details. Best regards!.
  • 109 Answers
I think tou may have a problem with either your pinion gear or your hour gear, or in that area where your calender is. Let me know what you find out.We can go from there.
Posted on Jun 29, 2008
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
I have a 7 year old Raymond Weil Women's Parsifal watch, stainless steel, bracelet, rectangular face. The outer face in stainless steel, that has four roman numerals on it, has somehow fallen off, or...
If you are talking about the bezel, which is the bit on the outside of the watch, you should contact the Raymond Weil repair centre SWICO. They repaired my Othello when half the bezel fell off. They had it back to me in no time! Their details are on the Raymond Weil website:
http://www.raymondweiluk.co.uk/t-faq.aspx
Good luck
May 11, 2010 | Raymond Weil Watches Tradition 18K Gold...
How to set rolex datejust turn-o-graph 116263 time
Unscrew the crown, pull it out and set the time by turning it. After setting the time push crown back in and screw it back on flush with case. Rate me, plz.
Mar 15, 2010 | Rolex Datejust SS
How do you open the latch on a Rolex datejust watch
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
Feb 08, 2010 | Rolex Datejust SS
Can you please tell me how to set my Rolex Oyster Perpetual Datejust? Day light savings toime ends this evening and the watch needs to be set back 1 hour.
Unscrew the crown and then pull the crown out to the second click and turn. When done push the crown back in and screw the crown back down.
It is very important to screw the crown back down. If this is not done the watch is NOT water resistant.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 31, 2009 | Rolex Datejust SS
How do i remove the bezel to my rolex datejust
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
Oct 24, 2009 | Rolex Datejust SS
Oyster Datejust White Gold RX579 Ladies - faux
Pull the clasp where the Rolex crown is. It may be quite stubborn/stiff.
Aug 12, 2009 | Rolex Day-Date President 118239 Wristwatch
Does anyone have a manual for a datejust rolex
No, there isn;t any downloadable manuals for Rolex watches, but operation of Rolex Datejust is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in date setting position,
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Feb 03, 2009 | Rolex Datejust SS
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Rolex crown problem
i have the same watch, with the same problem, i called rolex, and they told me that only a few odels of rolex watches do this, you should either take it back to the manufacturer,or take it apart and re fix the adjusting peices that work the hands when you try and turn it clock wise.
Jun 05, 2008 | Rolex Day-Date President 118238 Wristwatch
Rolex Day-Date President 118238 Wristwatch Logo
128 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
