Question about Frigidaire GLTR1670A Front Load Washer
Possible timer and/or spin problem
Washing machine will not spin. just does the wash or rinse cycle back over and over again. spins one way for a bit and then spins the other way for a bit.
  • robert samples May 11, 2010
    how many clothes are in the washer when it does this
  • 868 Answers
If you have a Maytag check out the R-11 contact on your control board,it will be fried .If this is the case,replace the control board and the wax motor.If not ,it's time to replace the motor/motor control board...... Please leave a Rating !!! Thanx!
Posted on Jun 05, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 05, 2008
    Same applies for Frigidare except the R-11 wont be issue,Instead check your door lock assembly first off.
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Not draining after rinse cycle
replace the timer it has a bad spot inside of it in this segment of the timer and isn't passing voltage for spin,when you forward it then it gets power again,they do wear out too
May 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washing machine won't rinse or spin?
looks like ur timer is not working and u possible have to replace it.....check with ur washing machine repair man
Mar 12, 2009 | Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    My washing machine is tripping the circuit breaker
    sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
    Jun 14, 2008 | Washing Machines
    Maytag Washing Machine Stops after wash cycle...
    sounds as if you have abad contact in the timer
    advance the timer to a different spin cycle and see if it spins
    then bo back to where it stops
    if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
    Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
    Washer stops after wash cycle
    the timer is bad you could try cleaning the points by taking it apart very hard to do though
    Aug 27, 2007 | Kenmore 23822 Top Load Washer
    Frigidaire GLTR1670A Front Load Washer Logo
    47 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
