Question about IBM Infoprint 1532 Laser Printer
How do I reset the maintence kit counter for an Infoprint 1532?
    Scholar:
  • 126 Answers
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Posted on Oct 19, 2010
  • info5068 Mar 01, 2011
    Pirla sulla descrizione tua hai invertito i tasti
    Forse non sai quale la destra o la sinistra
SOURCE:
Why is my infoprint 1532 saying load mp feeder?
Driver is telling the printer to print single sheet. Load a single sheet or fix your driver/software settings.
Jul 09, 2014 | IBM Infoprint 1532 Laser Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
Refilled toner and now printer reads - 30 invalid refill
The toner used must be for a different printer. That error message is displayed when the chip on the toner is not the correct one for that printer. It may be a defective cartridge, or the incorrect model. Try to go back to the place you bought it and return or exchange for the correct one.
Jun 16, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 printer not working
count the beeps, the number of beeps detemines the error.
Nov 14, 2008 | IBM Infoprint 1532 Laser Printer
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
Infoprint 1532 ibm micr printer
This unit is the low voltage type 110v compared to Australia voltage which is 230v therefore you will have to buy a new printer
Dec 29, 2007 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
6,937 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
