Question about Xerox Phaser 6120/YN Laser Printer
Phaser 6120 "Paper Size Mismatch" Error
My 1.2 year old Phaser 6120 has all of sudden started printing on only 3/4 of the 8.5x11 paper and an error pops up stating "Paper Size Mismatch". The top of paper has a rather large white space as if the top margin is about 2-3 inches from the top. I have checked the Paper Size settings and they are fine for the paper we are using. In fact the settings have never been changed. Also, I cleaned the media feed rollers with alcohol and that seemed to help for a day or two.
Interestingly enough, after trying to print a page about 4-5 times, the printer eventually prints it correctly. But if the printer is inactive for any length of time longer than 20 minutes, the problem appears again.
Xerox seems to think it is a paper feed sensor. Of course, the warranty ran out in March of this year and they will not repair/replace it.
Any suggestions as to what this may be and can it be fixed??
thanks,
Steve
  • linbaut3
    linbaut3 Feb 01, 2013
    Has this problem been resolved? I too am having it. would appreciate a fix.
  • 2072 Answers
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
Posted on Feb 09, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Posted on Jun 18, 2009
SOURCE: Xerox Phaser 6120 registration problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} We had purchase our Xerox Phaser 6120 printer in 2007.
Last one month is past we can’t printing our staff. We made complain regarding the same to Sunshine Service they told us that the sensor is gone, and they say its every difficult to get it, but they are trying to get it. Also we have spent on baying new toners for the same which is become useless now.
Pls. reply to mozaicdesign@gmail.com
Posted on Jul 10, 2009
SOURCE: My Phaser 6120 leaves light lines across the face
Lift out imaging unit and look down and back toward you, may need flash light, and you will see a 5" x 1/2" piece of glass. Carefully wipe it with soft cloth. Toner gets on this glass and creates the streaks. Often means a bad toner cartridge is leaking toner. Ron
Posted on Jul 12, 2009
wrinaldo
  • 185 Answers
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Posted on Aug 10, 2010
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Paper mismatch displays on the printer. I have to pick the paper size manually on the printer to print. How do I stop this error?
Make sure that the paper size of your document, and of the tray are set the same - if there is any conflict you ned to resolve it each time.
Jul 01, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
When printing business cards, I get an error on the printer. It will print other documents
did you set the paper size to the business card size? if not the machine will expect standard size paper and give you a size mismatch error
Oct 20, 2009 | Brother HL-2170W Laser Printer
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Mar 11, 2009 | HP DeskJet 5550 InkJet Printer
Qms 2200 paper mismatch error
Initial Thoughts
The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing.
However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch.
Insight
Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere.
The three software applications I referred to are:
1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
Jan 23, 2009 | Minolta magicolor 2200 EN Laser Printer
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Error message 490 mismatch
mismatch occurs when printer paper settings and document page size are not the same, check document page size.check print driver settings.
Nov 21, 2007 | OKI C5200n Laser Printer
Xerox Phaser 6120/YN Laser Printer Logo
850 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
