Question about Navman PiN 570 GPS Receiver
Charging socket has come out
Can anyone tell me how or where can I get my Navman PiN 570 fixed?. The chrome socket that the charging cord fits into has come out
  • 2 more comments
  • npva Jun 22, 2008
    I have had the same problem. My unit won't charge and after wiggling the charger into the socket all my info is wiped out.
  • Anonymous Jul 05, 2008
    Your comment that you "hard wired" it. What did you do? I thought I would hook up a more sensible connector to the pcb but not sure which is the + & - from the battery as there are 4 wires. Would that be the way to go & could i assume that they are the black & white wires not the red & green?
    gergmu@gmail.com
  • cool lillte Jul 06, 2008
    i have the same probem, can anyone help me hard wire it,the plug has completely broken off [pin 570].in my opinion what a stupid plug idea.
  • castlepsaint Feb 12, 2009
    Same here got the bloody thing in bits want to soldier a decent socket on it Please can someone tell me which colour is + and which is -
Point yourselves to here for either a socket or repair
http://www.ipaqrepair.co.uk/view_product.php?product=841
Posted on May 27, 2009
I have the same problem. can anyone help me to hard wire a pin 570sat navplug which has copletely broken off in my opinion what stupid plug idea.
Posted on Jul 06, 2008
I had the same problem about the stupid socket. Now it only charges at a very specific angle in my car. Of course, I found it dead in many morning when I get into my car. Could you also please let me know which ones are + and - so I can wire it with a better socket? Thanks. My email: sodium<at>gmail.com
Posted on Jul 05, 2008
DOnt know where you can get it fixed but I "hard wired" it so it has now become a GPS only.
What a stupid plug they came up with (so much for supporting Kiwi made)
The amount of stress that is placed on the plug while its pllugged in and your driving,something has to give sooner or later.
Posted on Jun 26, 2008
Charging light not coming on
I had the same problem, took the thing apart and checked voltages with a multi meter the battery voltage was 1.5 volts checked all connections nothing wrong put it back together" no go" held the reset button for over a minute, lovely green flashing light! hope it works for you
Jul 03, 2009 | Navman PiN 570 GPS Receiver
Pin navman handhelp pc will not work off battery
Try holding soft reset for a couple of minutes whilst charging. If this does not work leave pda charging with hard reset switched off BUT all data will be lost. Then move hard rest and if you are lucky the green charging light will start flashing and you can switch on. It sounds as though you have flat battery and if left too long restarting becomes very difficult as the motherboard cannot start the recharging process while the pda is switched on. This is true even with new batteries which can be supplied flat if old stock.
Even liquid damage is unlikely as there are so few exposed connectors. I have not tried it but gently drying motherboard with a hair drier on gentle setting and cleaning battery connector and screen ribbon cable before assmbling might work. Treat both connectors as being etremely fragile although they are more robust than you might think. But treat them with extreme care as repairs to them would be more expensive than the value of a working pda.
Jun 09, 2009 | Navman PiN 570 GPS Receiver
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Pocket pc navman 1022 charger and charger jack pin
sir, i have pocket pc 1022 navman pin 570 is not connecting with my pc.
May 16, 2009 | Navman PiN 570 GPS Receiver
Naveman PIN 570 gps receiver problem
i get the "waiting for gps" message if the gps unit is sending data to the main unit, but no satellite signal is found.
does the unit have sky view?
Sep 16, 2008 | Navman PiN 570 GPS Receiver
Pin 570 not charging
the connect where it plugs in is very flimsy you may need a new one. try adjusting the angle etc at which you place the unit on charge its very fiddly to get it right and a small nudge loses it
May 30, 2008 | Navman PiN 570 GPS Receiver
Charging socket on navman pin 570 has come out
These sockets are on sale if you google enough. Ebay seller totalviews for example. Check its the right socket and be prepared for very small presise soldering. when you open the case, take great care not to break/dismantle the rocker switch that protrudes as it has minute elements in it. If charging is a problem but the socket appears sound,m check the plug that goes into it and ensure the springs go in and out to hold it in place.F4therchristmas
May 19, 2008 | Navman PiN 570 GPS Receiver
NAVMAN 570 PIN
maybe there is a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board
Jan 23, 2008 | Navman PiN 570 GPS Receiver
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
Dec 03, 2007 | Navman PiN 570 GPS Receiver
Navman 570
LET UNIT POWER 100 PERCENT DOWN AND PULL BATTERY THEN MASTER RESET
THEN PLUG IN USB CORD AND SEE IF IT WILL LET YOU REINSTALL WITH OUT BATTERY IN IT
THAT HOW I JUST FIXED MINE 4 MONTHS AGO
Oct 10, 2007 | Navman PiN 570 GPS Receiver
Navman PiN 570 GPS Receiver Logo
114 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
