Question about Maytag Neptune MAH5500B Front Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
Sometimes during the spin cycle it sounds like there is a loose screw bouncing around. I took off the back access panel and ran a spin cycle with nothing in the drum... and no sounds created. Next, I threw two pair of jeans in the drum and started a spin cycle and within a few minutes the loose screw sounds returned. It happen randomly, but it sounds very bad when it does happen. Any clue how to address this problem? (rjs 6/4/08)
If still under warranty get it checked out . same problem and cracked my outer drum. leaks water now outer drum costs $427.00
Posted on Jun 06, 2008
    Problem Solver:
  • 14 Answers
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Posted on Jun 05, 2008
On start up of spin cycle noise can be heard intermittently, sounds like a loose belt bouncing around, only heard on power up intervals of spin cycle
try to locate your drive belt for the agitator. if your drive belt doesnt need to be replaced it may be the gearbox
Jan 29, 2011 | Washing Machines
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't drain or spin
my hot pointtopload will not spin or wash
Jul 07, 2008 | Hotpoint VBSR3100D Top Load Washer
Removal of front assembly (Maytag MAH6500AWW)
remove the front ,everything thats in front of the tub.Remove the fins attached inside of tub ,remove any bolt you see .Remove the tub
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Jun 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
620 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
