Question about InFocus ScreenPlay 4805 Multimedia Projector
Reverse projection upside down
I bought a ceiling mount for infocus lp420. It hangs upside down. How do I reverse projection so that I can watch it
  • Anonymous Jan 23, 2009
    can't hang from the ceiling because the screen is flipped? what to do?
  • David Payne
    David Payne Oct 31, 2014
    TRY A DIFFERNET MOUNTING BRACKET. FOR EXAMPLE A SWIVAL MOUNT. OR GO TO A METAL FAB SHOP AND HAVE ONE MADE. YELLOW PAGES.
Flip your screen upside down too
Posted on Jun 17, 2008
Go to Settings--> Systems menu and choose and turn off ceiling. Good luck!
Posted on Jan 25, 2009
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
Turning it back to normal after ceiling mount for LP755
hi,
1. perss menu button
2. select controls
3. then select ceiling projecton (When you turn Ceiling Projection on, the projector turns the image upside down for ceiling-mounted projection. Highlight Ceiling Projection, then click either button to select turn this feature on and off.)
ok
Dec 21, 2010 | InFocus LP 755 Multimedia Projector
How to turn the screen upside down for optoma projetcor
Found this on the InFocus site:
. You can reverse or flip the image for installation in a rear projection system or on the ceiling. To reverse or flip the image, press the Menu button on the keypad. Go to Main > Setup > System. Select the Rear checkbox or the Ceiling checkbox.
Jack - allprojectorlamp.com
Nov 25, 2010 | Office Equipment & Supplies
The image from the InFocus is upside down. Do not have a users manual. thanx, mike
In the main menu, go to Settings, select System, and uncheck Ceiling (that setting is to allow it to be mounted upside down from a ceiling mount).
Aug 10, 2010 | InFocus X1a DLP Projector
Projector is suspended from the ceiling upside down and so it is projecting upside down. How do i get it to project the images the right way up?
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
Jul 07, 2010 | Audio Players & Recorders
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Feb 23, 2009 | ViewSonic Office Equipment & Supplies
Need to invert the picture--ceiling mounted
The SYSTEM menu provides options for ceiling mount and rear projection. From the main menu, select SYSTEM, move the cursor down to CEILING and then click the SELECT button. That should put a check mark on that option. Then go to PREVIOUS and finally EXIT the menu,
Aug 19, 2008 | InFocus ScreenPlay 4805 Multimedia...
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
2,042 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
