It could be a safety protection meaning you could have a shorted speaker check all speakers and wiring, or it could be a defective volume control, try cleaning the volume with a contact cleaner spray you can find at any good electronic store (you normally have to open the radio to reach the POTENTIOMETER/VOLUME) to be able to spray inside it, than alternate (high/low) the control repetively to move/clean the volume's circuitry
Your amp has two channels - "normal" and "drive." When you are on the normal channel, the "volume" knob controls your gain. In the "drive" channel, the drive knob controls your gain. In both channels, the "master" knob limits how loud the amp will get.
Most likely, you are on the drive channel, so the volume knob will have no effect. Try pushing the "channel select" switch. You should notice the channel indicator lamp (next to the drive knob) turn off. When it is off, you are in the normal mode. Yellow = drive, and red = "more drive."
Experiment with different settings to get a variety of tones.
To get the most out of this amp, try reading the manual, available online here: http://www.fender.com/support/manuals/pdfs/manuals_elec/guitarpdf/Hot_Rod_Deluxe.pdf
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
volume control knob is damaged inside ,try to put 3drops of
kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
