Question about Goodman CLQ36AR49 Air Conditioner
A/c works but fishy smell coming through vents
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Is this an upflow or downflow unit? (vents in the floor or ceilings?) If an upflow, the coils needs cleannings and disefectant added. (mold-- bacteria--slime-- gooks---darkness plus moisture = bacteria growth.
Posted on Jun 09, 2008
2005 dodge neon, transmission oil smells fishy and coolant level is going down and engine is over heating and fishy smell is coming through the vents. What could be possible problems? I'm posting photo of...
Do u get smoke from vents? sounds like AC evaporator problem. Trans oil is a separate issue. May just need servicing. Have the cooling system pressure checked. Good luck
Jul 17, 2017 | Dodge Cars & Trucks
Fishy smell coming from breaker box and dryer tripping breaker
The problem is probably the breaker box. The fishy smell can be caused by the plastic housing melting so this needs looking at.
Dec 21, 2012 | Frigidaire Electric Dryer
Fishy smells relating to spirits
WAY FREEKY!!!! NO SOLUTION HERE.
Oct 10, 2012 | wikipedia.org
Smelling fishy when runnig for a while
First make sure that the unit is clean underneth. Unplug and clean all lint debris. Make sure that your dryer vent is working properly.
Sep 24, 2011 | Zanussi TC7114W Electric Dryer
The cool air blowing out has a fishy smell.
Hi!!
That's the smell of foul water, make sure to frecuently empty the drip pan, wash it and desinfect it using a couple of drops of clorox or other desinfectant.
Don't forget to rate this post!!
Jul 12, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
Funny fishy smell coming from 95 tiger 855 when it starts up. just changed the battery and can be difficult to start.
Some high heat paints smell fishy after the motor warms up and will continue to do so until the paint finally dries. Remember that your muffler resonator chamber can also collect moisture and create mold if stored for long periods since most of these use fiberglass to dampen sound.
Mar 09, 2010 | 1995 Triumph Tiger
A fishy smell coming from fridge
if its onb the back wall in the upper right corner 1/2 turn then pull down
if in the toe kick
1/2 turn then pull straight out
then push lock and light for 5 secs to clear change lite
Oct 08, 2009 | Jenn-Air JCD2389G Side by Side...
Fishy, steam odor coming from AC vents
Forget the radiator tank. Your AC 'Condensate drain' hose is plugged up. This is a common problem. If you know where the hose comes out under the car you can ( carefully ) push a wire up it. If you're lucky it's plugged near the end by a mud-dauber wasp. If not, take it to your dealer and see if you can persuade the write-up guy to show you where the drain outlet is as a gesture of good faith. If they insist on charging you money, consider that when you buy your next car...
Dec 30, 2008 | 1994 Lincoln Town Car
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Goodman CLQ36AR49 Air Conditioner Logo
181 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
