Question about Toshiba 27AF42 27" TV
Toshiba 36a42 picture problem
Turn the unit on and the picture is too big for the screen. Acting as if picture is being zoomed-in on. my Toshiba CN3081B Cinema Series also looks like the picture is zoomed in on. I've searched for a manual and can't find one. Running through the menus offers no help.
  • 487 Answers
Please FOLLOw this LINK and you will have the manual you need good luck
TOSHIBA
Posted on Jun 05, 2008
  • 3,037 Answers
You should check your remote for an "aspect" or "picture" button to see if you can change the format of the screen. You might be on zoom, change it to 16:9 or full screen.
Let me know if you are still experiencing this issue after doing this
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Master:
    Sergeant:
  • 461 Answers
Try to reset as below,
turn off the TV, remove the power supply from the main socket.
leave it for about 20 minutes
Turn it on again...
Will the Toshiba Model 36A42 work without a converter box?
The short answer is no. The reason for that is because it's an analog TV and has a standard tuner which is now obsolete because of the changes to all digital programming last year. You won't be able to use it with out a converter box. I won't recommend a particular brand or model, that would be your choice. Here is a selection of "boxes" available.
http://www.google.com/products?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=Digital+to+analog+converter+boxes.&um=1&ie=UTF-8&ei=GVSxS9WXE4-CswPd27XKAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg
Mar 30, 2010 | Toshiba 36A42 36" TV
Too much red in picture unable to get it out
The most common cause is the emission of the CRT electron guns are decreasing. They are going out of range and of proper balance in relation to each other for the AKG (Automatic Cathode [K] Gain) circuits in the CRT drive circuits to compensate for proper colour balance and colour tracking.
A less frequent cause are components going defective in the CRT bias and drive circuits.
I would be considering a new TV set with this type of fault condition. The cost of servicing this would be expensive.
Jerry G.
May 15, 2009 | Toshiba 36A42 36" TV
Toshiba no video sound is fine
If you can see the menus this means the CRT, high voltage, scan amplifiiers, the output video processor, and CRT drive circuits are working. The fault is most likely in the video section of the input select circuits.
Maybe the Toshiba parts department can supply a service manual for your set. With a signal source, a scope, and a DVM, an experienced technician can troubleshoot your set to locate where the failure is occuring.
I have not serviced this model, but in other models I have found the main input select IC to be defective. In some cases I also found a bad voltage regulator IC that supplies the input section has failed.
Jerry G.
Dec 16, 2008 | Toshiba 36A42 36" TV
Toshiba 36A42 36'' T.V.
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
Jerry G.
Dec 14, 2008 | Toshiba 36A42 36" TV
Brightness on my tv quit workin
open your tv.At the back you see a plyback,it is big parts of tv with a wire attached to the picture tube,that is plyback At the buttom you wiil see a two knob, the lower knob is for the screen and the upper knob is for the focus.Adjust the lower knob or screen .
Nov 16, 2008 | Toshiba 36A42 36" TV
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
Toshiba 36A42 TV. Dim Picture
Check the "screen" control on the flyback (lower knob) its easy to hit moving a board around. Try to adjust back to its original setting. Look for where the dust is, it should be on top. Or any marks might help. Other wise adjust slowly, back off if any retrace lines appear, with user settings at there normal settings.
Oct 27, 2007 | Toshiba 27AF42 27" TV
Menu pop ups
dopy, the problem is leaky tact switches on the control board, have changed out many of these especially on the 2003 model which of course is the 32A43, part number for the switches is 23344443, swap them and your done, BMW Rider
Sep 06, 2007 | Toshiba 32A43 32" TV
Toshiba 32A43 Horizontal Bars, pop, no picture.
First of all, there is no such thing as a "high power flyback converter". There is a flyback transformer, but if it was bad you would have absolutely no picture at all. The fact that you dont even know what the basic components are suggests that you should not be "diving in" to someone else's TV. Do everyone a favor and allow an experienced tech to service the set.
Jul 24, 2007 | Toshiba 32A43 32" TV
Toshiba 27AF42 27" TV Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
