Question about Sony KP-51HW40 51" Rear Projection Television
TV couldn't turn on. No picture
My TV couldn't turn on. The red light flashes six times.
  • 2 more comments
  • smodi65 Jun 30, 2008
    The TV clicks a few times when trying to turn on but won't turn on and blinks a red light 6 times. Repairman can't fix it.
  • kdawg51 Jul 03, 2008
    Same issue front red light blinks 6 times where can i order the parts
  • kdawg51 May 11, 2010
    of course silly by me the six blinks were for a KP-61H10 SONY PROJECTION TV Hopefully i have the same problem that you have If you happen to know if that would work also that would be much appreciated. thanks Kevin
  • lalov350 May 11, 2010
    tv want turn on has code 4
Had the same problem on my samsung LN-T4066. TV repair shop said it was fried. Couldn't be fixed.
Before I trashed it I took it to the Geed Squad at Best Buy. They sent it to there repair branch in Dallas. They fixed the problem for $84.00 ! Plus shipping. Said they had to replace four "caps"
Don't know what the caps are, but I was pretty happy with the Geed Squad.
Posted on Jun 29, 2009
  • 60 Answers
I repaired a KP53SH30 with 6-blinks error.
Sony says the error indicated loss of or short on the 5V regulator. The 5V regulator was bad, so I looked at the 6-volt regulator (it supplies 6-volts to the 5-volt regulator input.
I found a bad capacitor on the "G" board. The top was bulged. It was in the 6-volt power supply. I replaced the 6-volt regulator, the two caps on the input, two caps on the output. I also replaced the comparator chip. I don't know what part was bad, but these parts did the trick. I bought all of the parts at Mouser for about $10.00.
If you are a techno, I can send you the service manual if you need it.
I just noticed your code is 4-blinks.
Sony says it indicates +/-15 volt not supplied, and IC8003 is faulty. Hope this helps,
Dan
Posted on Jul 02, 2008
  • 1 more comment
  • Dan Smith
    Dan Smith Jul 02, 2008
    Sorry,
    I meant to say the 5-volt regulator was good!
    Dan
  • Dan Smith
    Dan Smith Jul 03, 2008
    Here's the stuff I ordered from Mouser.
    I ordered a variety of capacitors.
    526-NTE303 1g HEATSINK COMPOUND (for 6-volt regulator)
    647-UPS1V471MPD 35V 470uF 10X20
    140-HTRL16V1000-RC 16V 1000uF 105C
    661-EKME250ELL470ME1 25volts 47uF
    140-HTRL16V4700-RC 16V 4700uF 105C
    852-PQ1CG2032FZH 40V 3.5A, 70kH (6-volt regulator)
    526-NTE943M DIP-8 LOW PWR V-COMP
    Like I said, I don't know what part failed, but the parts were cheap.
    I'd look at the 5V regulator and surrounding caps as well (on main board).
    I don't know how to upload the service manual. If someones knows how, I'll do it, or I'll be happy to share it via e-mail.
    -Dan
  • Dan Smith
    Dan Smith Jul 04, 2008
    Kevin,
    I believe the Sony error codes are a Sony standard.
    You could try searching Agoraquest, though, I think you may have to pay to access their stuff.
    I've repaired 6 free projection Tv's this year. The Sony has the best picture of all that I have fixed(Hitachi, Toshiba, RCA, Samsung).
    All of the sets I have fixed so far had one or two bad capacitors. They look like they are bulged on the top. If you see one, it's probably a good place to start.
    Best of luck,
    -Dan
2 Suggested Answers
  • 5221 Answers
SOURCE: the power red light keeps flashing six times
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
Posted on Apr 26, 2010
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
My sony won't turn on. when I use the remote to turn on it flashes green six times, I hear a click and then it flashes red six time.
six times means the thermal fuse on top of the lamp tripped. Replace it and give it a good cleaning and it should work.
Feb 20, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Will not power on, red light flashing six times
the problem is in the power supply most likely. The overvoltage protect circuit is causing you not to be able to turn the tv on. This is common to all tv's. Solution unfortuantely is get another tv unless you know someone who can either work on or replace the internal power supply
Jul 01, 2009 | Sony KP-61HS30 TV
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KP-51HW40 51" Rear Projection Television Logo
432 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
