Question about JVC LXD300U clearance Multimedia Projector
Jvc Lx-d300U Lamp replacement issue
I have a JVC LX-D300U LCD Projector. It had been great until I needed to replace the bulb. I purchased a new replacement bulb and installed the bulb properly. However I do not have a manual for this projector and I believe there must bbe some way of resetting the the system to accept the new bulb. Maybe by pressing a combination of buttons? I don't know? Can someone offer assistance or provide me with a copy of the manual?
Thanks - Jason
  • JasonR Jun 05, 2008
    Jvc
  • klkh29 Apr 11, 2009
    i replaced my lamp on jvc rear projection tv and on the instruction it tells you to push the lamp reset button but i cant find any type of button on the tv
5 Suggested Answers
  • 13433 Answers
SOURCE: Playing blue ray movies on jvc dla sx21 projector
It should work right away. Try again, restart the projector and ps3 make sure everything is connected and the input on the projector is on dvi.
Posted on May 17, 2008
Did any suggestions work? I have the same projector and am thinking of
upgrading to bluray dvd player. When i tried before, I had HDCP issues. Thanks.
Posted on Mar 20, 2009
projdoc
  • 2236 Answers
SOURCE: Blinking Stand-by and Operate
the lamp needs replacing.
Posted on Aug 19, 2009
SOURCE: Lamp replaced, sequence from Manual (p.49) for 2010+ hrs fails
Apparently, the above posted steps do work, but they are finicky. The manual suggests that you do the aforementioned steps with the remote - I had tried with the remote and when that did not work I tried directly on the controls on the unit itself. Neither had worked - after multiple attempts, hence the posting above. The solution was that the various steps need to be done speedily - when I previously did it I apparently did not press the sequence rapidly enough. Nothing in the manual suggests that this is the case (and in fact I thought I had previously followed the steps in rapid succession on at least one of the many times I had tried, but apparently not quickly enough). I never could get this rapid succession of steps to work with the remote (as the manual said I needed to), but I did ultimately get the rapid succession of steps to work when done directly to the unit itself. The first three steps need to be completed within approximately 1-1.5 seconds, the final push of the volume+ button did require 2 or more seconds before the process was recognized (and complete). Never did have a single FixYa party try to address my issue - perhaps you only really get responses from them when you pay for their monthly service.
Posted on Sep 26, 2009
SOURCE: My Blueray picture is 'protected' when I connect
JVC DLA-SX21U has not built is hdcp. use componant cable or buy hd fury
Posted on Mar 13, 2010
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
Trying to reset hour times after lamp replacement but remote has no ok button
1,turn on the projector
2,"menu"---"setting"--- "reset lamp timer"--.....
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Jan 10, 2014 | JVC TS-CL110UAA Projector Lamp
Origional Epson 3010 bulb burned out after 2 years. New bulb died in a month
our company supply the Original lamp ,unit price is USD200
have a nice day!
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Nov 02, 2013 | JVC Dla X3 3d Projector
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Excuse me I recently changed the bulb on my JVC HDMI DLA-1 Projector and it still says I need to change the bulb how do I solve this issue?
Agreed with Fathi, Press and hold down the video, settings and quick alighn + > at the same time for six seconds. While the stand by and operate indicators are on, press video, settings and computer buttons at the same time.
Apr 11, 2010 | JVC DLA-G15 Multimedia Projector
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Christie lamp explodes
the lamp VIP300w, with Hg
the lamp have the chance to explode,if the lamp used over 2200 hours
you can replace the lamp when it is about 2000 hours
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
Jerry Lampdeng Limited
Dec 10, 2007 | Christie Office Equipment & Supplies
114 people viewed this question
Top JVC Office Equipment & Supplies Experts
Electro Med Services...
Lampdeng.com
Lampdeng.com
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
