Question about Food Mixers
Hobart a200 first gear not working
First gear runs with little or no torque. I can feel a light ticking if i hold the gear shift lever.
  • 640 Answers
Sounds like the key is sheared on the gear.
Posted on Jun 07, 2008
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
1949 hobart a200 rebuild problem
Google Hobart --utube-ebay has 300 4sale somebody might know something--waiting on the chocolate chip cookies
Aug 02, 2017 | Food Mixers
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Food Mixers Logo
150 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
