Question about Canon EOS-20D Body only Digital Camera
How to replace lcd screen in Canon 20d
Hello, i recently dropped my camera and the lcd screen was broken. the camera works fine, it just won't display, all i see is a cracked screen partly white partly dark. so i ordered the lcd screen from canon parts for $75. now that i have it. what is the best way to install it. i have a photoshoot soon and can't afford to have it sent away for 3-4 weeks. i have not been able to find much information about the process online. any help would be greatly appreciated.
Although it's actually showing how to remove IR filter or something, it shows in detail how to get in there:
http://www.lrgb.com/20d.html
and look here for other similar info for other models:
http://www.jr-worldwi.de/photo/index.html?modding.html
good luck.  i'll be attempting this soon as my screen has been broken for 2 years!
Posted on Jul 31, 2008
    Problem Solver:
  • 10 Answers
I FOUND A GUY THAT USES NAME BRAND LCDS AND REPAIRS OR SELLS YOU THE LCDS NEW, AND THERE CHEAPER THEN ANYONE IVE FOUND, HE HAS REPAIR 3 FOR ME SO FAR. IF YOU CAN DO IT YOUR SELF YOU CAN SAVE 20-30 CAUSE THATS WHAT HIS LABOR COST IS PLUS FREE SHIPPING. http://j2agent.googlepages.com
Posted on Aug 05, 2008
Dropped Canon - Display Broken
Repair expensive, if possible. Replacement best option.
May 25, 2017 | Canon PowerShot SD600 Digital Camera
Canon 20 d power issues
I'm sorry but I think you need to have it checked by a pro.
Apr 22, 2017 | Canon EOS-20D Digital Camera
Rear lcd screen black in shooting mode but works fine in playback
Solved the problem by going to the Canon product support site. It seems that there is no problem at all. The way the camera is designed is the problem. To be able to use the rear display lcd as a view finder, the camera needs to be able to lift the mirror to allow the sensors to pick up the image and display it on the screen. The 20D does not have this abilitiy. Apparently some later models do allow you to raise the mirror. It was this feature on those models that led me to believe that the 20D should do this too.
Jan 25, 2010 | Canon EOS-20D Body only Digital Camera
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Canon EOS 20D Digital zoom failed
The autofocus mechanism on some lenses can be damaged if you manually focus while the camera is attempting to autofocus. Basically, you would be working against the motor and gears.
There is no need to download software before using the camera, however, I would suggest going to Canon's website and downloading the firmware upgrades for it. Here's the link:
Canon 20D Firmware Download
Hope this helps!
Oct 12, 2008 | Canon EOS 20Da Digital Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
Canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
Jul 11, 2008 | Canon PowerShot A630 Digital Camera
Cannon Powershot LCD Screen
If you can get a replacement screen (ebay from a broken camera with working LCD screen?), it's not too hard:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Connection Problem
I too have a Canon 20D and receive the same message. Zoombrowser works fine with my Canon G3, so the way I get around this problem is by using the other software that came with the 20D called EOS Viewer. This software will download your images every time. You might try sending a note to Canon's support team on the Canon website. They are very quick to respond to all questions and they can probably respond to this question too. Good luck!
Aug 31, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon EOS-20D Body only Digital Camera Logo
888 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
