Question about Global Marketing Partners LEADSINGER PRE-TEEN SONG CHIP Sound Card
No audio I just got a Leadsinger 2100 mic. I have checked the website and can find no solution to my problem. Everything seems to work except there is no audio...can't hear the music or singing. (Yes my TV is turned up.) I've checked the cables, reset everything and am now at a loss. Any ideas??
    Guru:
  • 61 Answers
Ar all chips compatible with karoake systems
no
there are various issues , model of the system the make ( magic sing will fit magic sing ONLY )
if laungage font is different example hindi etc then also it will not work
chips made for very old models may not work on new systems
example ed series chips may not work on KV and KH series
for more please email me on mumbai11@gmail.com
Jan 07, 2015 | LeadSinger Audio Players & Recorders
Lyrics stick when playing songs on Leadsinger MVK2
Firstly all lines have to be timed. Then they will scroll. Other issue is the microphone is 16 Bit and we use mostly 32 and 64 bit file names as well as allowed characters within a page. 16 bit dos is limited characters specially comma or ( ) [ ] } : # $ so on will not work with this mic. Convert what doesn't work with FileEncConverter (available on web) and they will work. This program removes what mic can't handle.. Good luck
Jun 25, 2012 | LeadSinger MVK2 Consumer Microphone
Wont turn on
Is the Mike an electret? Does it need a battery to work. If so try changing it or making sure it's inserted correctly. Does the on off switch feel sloppy and loose? If so it could need looking at. Also the wire for mics tends to take a beating. Check the connections on the plug end and make sure it's all connected OK. Don't forget a fracture can take place halfway along the cable in which case you'll need a multimeter. It will tell you if it's fractured but not exactly where the fracture is. If the mike gets it's voltage from the mixer or amplifier have you switched the phantom power on? If there's a plug and socket on the end of the mic also check that for fractures and again use the multimeter to measure continuity from one end to the other. Usually the braid is OK but check all wires anyway.
Apr 10, 2010 | LeadSinger LS-3000 Consumer Microphone
Everything works but mic does not go on on my leadsinger system lost manual
I am not sure if this is the same company:http://www.magicmicrophones.com/contactus.php I hope this helps.
Nov 26, 2009 | LeadSinger MVK2 Consumer Microphone
Power lost on Main Microphone.
sound like you've been f#$^%d I suggest you boycott the company if enough people do it they will be forced to bankrupt then the government can bail them out and own the company this would give them the power to do things like fire the c.e.o.... still doesn't help your situation but it's fun to watch on tv
Apr 29, 2009 | LeadSinger LS-3000 Consumer Microphone
No sound coming from wireless mic
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
Mar 28, 2009 | LeadSinger LS-3222 Consumer Microphone
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
My video isn't working right
I just fixed my problem and the mike is working great! Try holding the number 9 then press and release the power button. I found this on the Leadsinger FAQ section and it worked. I'm pretty happy, as I really enjoy the chips I have for the mic!
Mar 28, 2008 | LeadSinger LS-3000 Consumer Microphone
Computers & Internet Logo
119 people viewed this question
Top Global Marketing Partners Computers & Internet Experts
PinkLisa
Level 1 Expert
ElvinSloth
ElvinSloth
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Global Marketing Partners Computer and Internet Expert? Answer questions, earn points and help others
