Question about Philips 20PT653R 20" TV
Is it DVT ready?
How do I know if my TV has an Advanced Television Systems Committee (ATSC) tuner. In other words, how do I know if it is digital ready or just analog?
  • Parsi Jun 05, 2008
    Forgot to tell you: I have a Philips 20PT653R 20" TV. I bought it in 2007, but it was made in 2005.
    Your friend, Parsi
  • 65 Answers
You have an analog TV. If you are asking for the purpose of getting a DTV converter box, you only need it if you use antenna for signal. If you have cable or Satillite there is not need for the coverter box.
Posted on Jun 05, 2008
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Is the tuner built-in ATSC, or NTSC?
Your tv tuner is set to function on both NTSC and ATSC. See below for the reference
NTSC (National Television System Committee) is the analog television broadcasting standard used widely in North America. It is referred to as a 525-line standard, but actually displays only 480 lines. NTSC is to be replaced with new DTV (Digital TV) standards in the coming years.
ATSC (Advanced Television Standards Committee) creates the technical standards for the US digital television system (DTV). These standards are expected to be used in most new televisions, as the US television system shifts from analog to digital.
Nov 10, 2010 | Toshiba 57H84 57" Rear Projection...
I want to turn my regular signal into an HDtv signal. How Can I do this?
Your, ahem..., your Regular Signal?
Please describe this more in detail, what you are trying to do?
There are upscaling dvd players these days that can upscale regular dvds to HD...
What regular signal are you talking about? Over-the-air TV went to Digital recently ... so the Regular TV old style signals are mostly gone from the airwaves. That was NTSC (Never Twice the Same Color, no really Nation Television Sub Committee.) Now it is Advanced aka ATSC. Most tuners on newer tv's will do both NTSC and ATSC both on over-the-air and on most Cable TV systems.
Retrievo has you manual. You could probably also find it on the manufacturers web site...
http://www.retrevo.com/support/Philips-60PP9202%2F17-TVs-manual/id/446bh336/t/2/
Nov 23, 2009 | Philips 60PP9202 60" Rear Projection...
Do I need a convertor box with this tv?
No, All you will need is a Good external antenna, The good old rabbet ears you may remember from the past. RCA has a geed plat panel antenna for $30 found at most Best Buy, Wal-Mart stores
Jun 25, 2009 | Sylvania 6615LCT 15 in. EDTV-Ready LCD...
Polaroid Model TLX01911C
Greetings!
This set is listed as having the ATSC (Advanced Television Systems Committee) tuner. This tuner provides reception of digital over-the-air (antenna/rabbit ears) signals and would therefore not need a converter box fir that use.
If you are trying to receive un-encrypted digital signals from cable, the ATSC tuner does no good. The set would then require a QAM (quadrature amplitude modulation) tuner. I am not sure if this set has a QAM tuner or not. Even if it did not, your cable provider must provide a way for you to receive their signal and should make their converter box available to you.
Hope this helps explain things a little,
Rob
Jan 14, 2009 | Polaroid TTM-2003 Combo
Dtv ready?
Going to the following link will help you to find out if your television is DTV ready or not:
http://www.dtvtransition.org/index.php?option=com_content&task=view&id=51&Itemid=94
Using their online tool, select the Brand (Akai) and the Model from the list. If you cannot find your model in the list (which I was not able to for your television), they are saying that you most likely do not have a digital tuner.
All is not lost, however. As stated on the aforementioned site, you can consider one of the following options:
  • Purchase a digital-to-analog converter box that plugs into an existing television. The boxes, which are expected to cost between $40 - 70 will be available for purchase in 2008. Beginning in February 2008, U.S. households can request up to two coupons valued at $40 each. Each coupon can go toward the purchase of a single set-top converter box that will allow you to continue watching FREE "over-the-air" television on an analog set.
  • Subscribe to a cable, satellite or telecommunications service provider if all desired local broadcast stations are carried by that service.
  • Purchase a new television set with a built in digital tuner.
    Listed on the page is further information that may help you to determine the status of your TV:
  • Consult your owner's manual. If that's not possible, you may be able to look up information about your TV set on the manufacturer's website. Or, you can take an up-close look at your TV set. You are trying to find out if your set has an input connection labeled "digital input" or "ATSC" (for Advanced Television Systems Committee, which is developing the DTV format).
  • If you bought your TV set before 1998, it probably doesn't have a digital tuner at all. Almost every TV set made before 1998 was a traditional "analog" set that can't display digital TV signals without either a special converter or a cable TV connection. If you bought a big-screen, projection TV between 1998 and 2004, it's possible there's a built-in digital tuner inside. But chances aren't great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
  • If you've purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores have featured digital tuners that will let you receive the new digital over-the-air broadcasts starting in February 2009. But be wary: It's not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as "HD-ready" or "HDTV monitor" sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You'll still need a special converter or a cable TV connection.
  • Jan 12, 2009 | Akai PT5492S 54" Rear Projection...
    Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
    Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
    unfortunately you have a
    • Analog TV Tuner NTSC
    and
    • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
    You need a tv that has this:
    Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
    So Sorry, the tuner is not Digital.
    Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
    Programing Broksonic TV
    Does it has a built-in Advanced Television Systems Committee (ATSC) tuner?
    May 09, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
    Is my tv digital compatible or not
    https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
    Here are some general guidelines that may help:
    TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
    If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
    Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
    Philips 20PT653R 20" TV Logo
    77 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
