1995 Mercury Cougar Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1995 mercury cougar and my speakers in the doors are horrible. I was going to have them replaced, but I don't know what size i needed for the front doors and the speakers in the back.
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Oct 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
10151
Points
147
I HAVE A 1995 MERCURY COUGAR XR7, BOSTONIAN EDITION. PROD DATE OF 7/95 I NEED TO REPLACE THE BACK BRAKE LIGHT/TAIL LIGHT LENS. IT IS ON THE TRUNK ITSELF. I'M GOING CRAZY TRYING TO FIND OUT WHERE TO FIND...
1990 Mercury Cougar Bostonian, mint condition... recently purchased. I hear a whisting/slight high pitch noise that seems to be coming from, in back of the glove box. Any suggestions or ideas?
Radio wiring diagram
dotted-line-527.gif 1995 Mercury Cougar Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Orange
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Dark Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5′ x 7′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Brown/Pink
pls rate
5helpful
How to find out the radio wiring harness color codes on a 1997 mercury cougar
hi
1997 Mercury Cougar Car Audio Wiring Diagram
8helpful
Program fob/reset keyless entry pad 95 cougar
If you open trunk and look on inside of trunk where hinge bolts are you will see code numbers . Owners manual will tell you how.
1helpful
Replacing door speakers in a mercury tracer
first remove any screws in door panel, then remove lock and window controls, then take flathead screw driver and SLOWLY pry panel off door. You now will have access to speaker. Speaker is held by 4 screws and wire harness that unclips.
Reverse procedure to reinstall. Door panel pops back in the wholes to reattach
2helpful
3answers
Tire sizes no sticker in the door
goggle mercury cougar owners manual is very long but its worth it. Oh the size tire is 215/555R16 there high profermance and low profile tires pep boys have them for $99 bucks a piece
Tire sizes
Open the front drivers door... or the passenger side front door... there should be a sticker there indicating correct tire sizes as well as pressures.
Robert
Please take a moment to rate this solution thanks
Keypad entery reset
go to the dealership.
1995 cougar window problem
If able pull the door skin off and clean the connections on the motor for the window if you cant get to it do what I do in my mustang ...give the door a few good whacks up towards the hinge side of door in the middle from top to bottom
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
