Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Hello hey i got a Motorola MTX2000.and when i hit the ptt buttion it does the beep is this because theirs no signal? and can you plz replay to csabia4091@bellsouht.net
  • 84 Answers
If it's a single tone try communicating threw it. some of them have identifiers in them. you hear a beep but other on the same chanel may hear a different tone. this has been added over the past few years due to people talking on top of eachother, it does this to let others know someone is going to talk.
Posted on Jun 13, 2008
My T5950 won't stop beeping when I push the PTT button. I tried holding the PTT in when I turn the unit on and that didn't stop it.
Very likely it is the battery. Beeping means not enough power especially when transmitting. Try charging the battery again, try transmitting again and plan on new batteries. They "wear out" even when not in use.
Oct 16, 2016 | Motorola Talkabout T5950 (7 Channels)...
SQUELCH NOISE AFTER PTT
Monitor function and PTT are often either side by side or on the same key. (Upper or lower portion of key). You may be hitting both or the wrong side of the button. Cheers.
Apr 18, 2014 | Motorola Mag One BPR40 Two Way Radio
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
My biggest issue is the "roger" beep. Want to use it for a hunt, but the beep is constant after hitting the PTT button. I have read that on some models, hold the + or volume button while...
Here is a link to the SX700 manual (very close match to the SX800, which we could not find a user guide for) http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Look on page 2. Check both the Keypad Tones and the Talk Confirmation Tone (Roger Beep) instructions, on the lower left. This should help you.
Best regards.
Dec 28, 2010 | Motorola Walkie Talkie 2-Way Radio
Cant hear talking with ear peice but I can hear the beep from the radio and the PTT works on the earpeice but thats it.
Check to be sure the earpiece is recommended for your type of radio. Be certain to have the radio turned off when plugging in the audio device. Then check you have the device plugged in all the way. You should feel a slight click when it is seated properly. Use the in-line-PTT only, not the PTT on the radio if this is the method you are want to consistently use.
Aug 31, 2009 | Motorola T7100 2-Way Radio
When I press the PTT button it will not beep after i talk
either that or take out the batterys and it will reset ist selft
Aug 08, 2009 | Motorola Walkie Talkie 2-Way Radio
2-WAY RADIO TROUBLESHOOTING
In a Motorola T500, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Good luck and kind regards.
Nov 03, 2007 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola t5100
In most Motorola T5XXX series/models, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Nov 03, 2007 | Motorola Talkabout T5100 (14 Channels)...
Roger Beep
Hi Helen,
On most Motorola radios, to remove the roger beep, while powered on, you need to press the menu button until the Roger Beep indicator in the display starts to flash. Press on the + or - to change status. Press on the PTT to save and exit.
Hope this be of some help. Pls post back if it worked or should you need additional information.
Oct 25, 2007 | Motorola TalkAbout T6530R (14 Channels)...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
75 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
