Question about Epson Stylus C60 InkJet Printer
C60 says full cartridge is dry
I tried to get one more print from my almost empty cartridge and it crumpled the sheet and jammed. It took awhile, but I got all the pieces of paper out and tried again, this time it refused saying the black cartridge is dry. I bought a new epson cartridge and put it in (same as I always do) and nothing. The cartridges didn't even move back to the printing position. Anyway, I've tried printing and I keep getting a message saying the black ink cartridge is dry. I tried doing the head cleaning process, switching the printer off and on, rebooting the computer, pulling the cartridge out and putting it back in again and same old message. I tried calling the epson troubleshooting hotline but got no fix- just a promise of a new cartridge. I took out the cartridge and looked more closely at it and saw a tiny metal needle like thing in the center of the clear plastic punctured hole for the ink. I pushed the needle thing in and the ink flowed freely. I put the cartridge back in the printer and STILL it says black ink is dry. The needle thing is no longer visible on the cartridge and everything seems ready to go except the program. HELP!
    Problem Solver:
  • 10 Answers
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Posted on Jul 07, 2008
Error E and 5
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has elapsed without receiving a response from the digital camera. / A print mode compliant with PictBridge is not selected. / A specified period of time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
Feb 18, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Machine won't print in black when colour cartridges empty
it is possible to print with only one cartridge that has ink as long as you take a piece of black tape and cover the front center of the empty cartridge and placing it back into the machine .you need to cover the clear plastic in center. Also to take off the power from on the machine press and hold power button for a few sec
Jun 17, 2009 | Brother MFC 240C All-In-One InkJet Printer
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Epson c60 problem
methinks you'll need to do a clean and calibrate on those new ink stations.
May 11, 2008 | HP PhotoSmart 7260 InkJet Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Not printing, please help
yohoo
It is usually one of these 3 things. Out of paper, paper is jammed or one of your ink cartridges is out of ink. But make sure your cartridges are seated correctly.
Davecapt
Mar 25, 2008 | Epson Stylus C60 InkJet Printer
Both the Red and Green lights are burning steady
k, heres a long 1...=P
>the green light is just your power light, if it is glowing, its on, if its blinking...its receiving a job/replacing cartridge/charging cartridge/or cleaning heads
>the red light being constant on is any of the following...
-ran out of ink, ran out of paper, or has a paper jam.
hope this helps.
PS: re-manufactured cartridges can not always be trusted...some companies accidentally send empties...simple mix up im sure,we're all human after all, but be on look-out.
Feb 08, 2008 | Epson Stylus C60 InkJet Printer
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Black Won't Print On MFC 420 CN
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Sep 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus C60 InkJet Printer Logo
105 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
