2003 Suzuki GZ 125 Marauder Logo
Posted on Oct 19, 2010
Loosing speed top end dropped by 15-20mph - 2003 Suzuki GZ 125 Marauder
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
258
Points
Tyre pressure is big one so easy to check so common not to
also checking your chain is tight enough but can still move 1-2cm this will cause low power at takeoff and gear slipping but if bike not new could need new chain and crank set wont break the bank hope this helps helped me
  • blackflo Feb 15, 2011
    I had same problem and when i stripped out the carburettor i found holes in the creases of the diapraghm. I think the replacement had modifications to its design so could be seeing alot of this fault (gz125 K6)
    After this replacement the bike was like a rocket in comparison
  • Anonymous Apr 11, 2013
    did you get a replacement diaphragm or full carb ?
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 • Motorcycles
1helpful
2answers
My jeep keeps bucking , my rpm and mph Gage's go up and down , along with the gas gage at drops to empty and comes back up. When accelerating it doesn't , just bucks. This happens very infrequent.
which of 3 engine do you have, gas or diesel and what size?
Are battery terminals clean????????????
Ill assume yes.
below will be 4.0L answers ,gas.
id say lost 12vdc power to EFI system and cluster.
the cluster dropping is lost power.
the cluster is computer in its own right.
and has 2 power pins, one is power to run, and power memory.
can be simple as a loose fuse.
to find it i inspect first. (im retired ET and can find them all)
if you had used a scan tool ($10) it would tell you why.
for example see all sensors go dead.
or the scan tool drops comms mind scan, lost DC POWER>
the scan tool will also tell you if the ASD relay drops and WHY!!!
if 12vdc did not die, first.
i start at the battery, after al batteries are weak technology, (acid/lead) some only last 3 years, (weak tech)
battery lugs corroded (at 4 ends)
2 cables 4 ends.
the hard part, (only) is the intermittancy.
cant fix working perfect cars, can not.
might be a loose fuse?
to isolate the true cause next time have all things ON , in car
head lights, HVAC blower on max. radio. all things.
now what dies????? a big big clue that.......!!!!
the power system is like a tree.
what branch is dead, puts us on track.
04 WJ jeep , i have the full factory FSM
can take you to the spot it fails.
lets say cluster power pin C1p7 drops dead (02 fsm names)
that means power from JB fuse 22 dropped. JB is cab box.
or its bad, (hair cracks in fuse, loose, or rusty) try a new fuse.?
or Fus22
it's input died, and that his the key switch bad, or before it.
called ST Run 21 (fsm)
see photos below for St run 21 feed, sources.
the PDC fuse top seen here, is PDC fuse F8 (engine bay)
if that top path is good, the the key switch is bad.
end story.
finding it, i use a logging voltmeter,
in the olden days, id have an analog meter sitting on passengers
seat, and at stall glance over, and go, gee, the F8 feed is good
so move my test wire to ST21 side, see it die or not.
walking the test wire from top of below to the cluster.
battery is top. last item below is cluster,
this is the fail path.
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
My 1996 gmc 3500 diesel starts up fine but when i cut it off must wait for it to cool off to start again
Compare cranking speeds cold to warm most diesels require about 375 RPM's cranking to start. NOW possibly a bad starter (dragging) voltage drop (high resistance) in cables. loose or dirty battery cable ends. To test voltage drop requires 2 people one cranking engine other watching volt meter. Place one meter lead on battery cable end and other lead on the other end of cable. Do this to all 4 battery cables. What voltage that can not go through cable will go through meter. So the closest to zero is the best. good readings are .02 volts for connections and .05 volts per foot of cable.
How do I repair the speed settings It only goes on fast speed.
The screws are roughly 8 turns in from fully out when starting to set the speed. On the lowest speed 13 revolutions of the planetary in 15 seconds is a good speed.
1helpful
2answers
Makes a funny noise when i go over a speed bump chevy 2001 mal
what sort of noise clunks&bangs could be anything from shock mounting bushes exhaust hanging mounts or suspsion bushes.it would be a good idear 2 have a mechanic put it up on a hoist 2 check it out
How to increase top end speed - 2007 Kawasaki Ninja EX250R
you can change the sprockets.If you go to a 16 tooth front sprocket. two teeth on a front sprocket is like droping 4 teeth on the rear. You could drop 2 teeth on the rear sprocket but a 43 tooth is probably harder to find. the usual choices for front are 14,15,16 tooth.
For the rear they are 44,45,46 tooth
The way to remeber gearing changes is on REAR sprocket is smaller=faster and larger=slower top end.
the FRONT is OPPOSITE to the rear smaller=slower and bigger=faster.
You may have to lengthen or shorten the chain depending whjch way you go.
At about 4000 RPM the check engine light flashes and there is hesitation. The read out says misfire in #3. I have a 2000 GMC Yukon, During regular speeds it is fine. There also seams to be a hesitation...
Your catylatic converter may be clogged if your loosing power or top speed is less than it was. You can check this when its running with a battery operated infared heat gauge. the temperature of the muffler should be around the same temp. as the catylatic converter.
2answers
I have a 1998 yamaha yz125. i recently rebuilt the top end. I also put new reeds in it, and new crank sills. It dont have any bottom end power once you get the rpm up you have alot of top end how can i get...
These bikes never had bottom end power, they only make it at the top. You would have to drop compression to help some at lower end but there would be sacrifices to high speed where this engine was designed to run at. Does it still have the factory pipe, if not it will be even worse! Sorry but in this case there is no good answer. Or at least one that you will want to hear.. Again sorry...
Speedometer problems
It may be that the speedo cable has come loose at 1 end and will need to be tightened back up. Sorry but not sure where ends are attached on your car.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
