Question about Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
Have a great little canon BJC 2010 printer and am getting a new PC. Can I use a 1284 to usb cable to get it to work? Running windows XP
    Problem Solver:
  • 18 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Posted on Oct 05, 2008
Bought compaq presario cq60 laptop and i am trying to find if it will hook up to my canon bjc-2110 printer.
If your Canon printer has a USB cable, then yes,your Compaq cq60 will work with it.
May 16, 2009 | Canon BJC 2110 InkJet Printer
Cable for USB conversion
YES. THERE ARE SEVERAL USB-PARALELL CABLES CABLES IN THE MARKET. JUST CHECK IN THE WEB OR YOUR HARDWARE STORE. PRICE SHOULD BE AROUND 15 TO 20 US DOLLARS, DEPENDING ON BRAND, QUALITY, ETC.
SOME OF THE (MOST) BRIG A DRIVER CD.
ONE THING YOU SHOULD HAVE IN MIND IS THAT WHEN INSTALLING YOU BJC-80 IT WONT PRINT UNLESS YOU GO TO PRINTER PROPERTIES, PORTS AND UNMARK "BIDERECTIONAL COMPATIBILITY", THE GO TO ADVANCED OPTIONS AND CHECK ON "PRINT DIRECTLY TO THE PRINTER", OR SOMETHING LIKE THAT. (SORRY ALL MY SOFT IS IN SPANISH...) RESTART THA COMPUTER AND ENJOY. I HAVE A BJC-70 AND A BJC-80, USE THEM ON XP SP2 AND VISTA. BOTH WORKING FINE. DO NOT EXPECT SPEED PERFORMANCE. GOOD LUCK
Mar 10, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 80 New Cable Required
You Can Get Them At Radio Shack, Circuit City Or Best Buy Maybe Even Wal-mart
Jan 07, 2009 | Canon BJC 80 InkJet Printer
My canon bjc-80 will not print
BJC-80, USB to PARALLEL cable & XP problem solved! I read all the comments, instructions, etc. and was ready to give up, but posed the problem to my son (who has a computer repair business, duh), and I'm not sure I have this correct he simply Dis-abled the bi-directional communications in the set up, gave the cable and printer a designated USB port, got the driver for the BJC-80 ... not BJC-85 ... and it works fine. I do not have the scanner cartridge but I have 2 BJC-80s and love them but gave up when got the new computer. Well, I just ran off 2 pages after cleaning the cartridges and cartridge holder with alcohol on TP, because they had dried up hard, and it works great in both B&W & color, at least on draft mode so far. (My son will not post anything because he does not want a bunch of calls coming in, and I don't know any more, but I just could not bring myself to give up these great little printers for on the go Realtors, etc. without another good old college try). Glad to have my printers back! Good luck.
Nov 16, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 8200 printer not responding:
Did you go to the Canon site and download the drivers? Also while at the site, check the FAQ's.
Sep 24, 2008 | Canon BJC 8200 Photo InkJet Printer
Canon BJC-250 Printer
sure...you may need to add the printer, again, after removing it. Also, did the new dell Vista disk for drivers and utilities come with? I'd advise going to Canon's page, and getting a more recent driver. The old disk from Dell or Canon, MAY NOT have the most recent driver set. Also, if you're using the print manager, that's a new download, for certain.
Feb 06, 2008 | Canon BJC 250 X. Files InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
328 people viewed this question
old marine
old marine
