Question about Frigidaire Washing Machines
My frigidaire washer will not fill with water! I have already cleaned the filer and drained and cleaned the lines still no water coming to the unit! Please help!!!
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    how old is this machine??
  • 487 Answers
Follow LINK to see the parts for inlet valves and or pressure switch
Posted on Jun 05, 2008
Frigidaire washer will not wash or spin
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washer model LAFW70000LWO leaking from bottom of washer
would suggest cleaning out the coin or filter trap to see if debris has clogged the drain lines. This may or may not be specifically for your model, however these are generics instructions that I found.
To check for a restriction in the drain line you will need to follow the steps below:
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
If any proves to be ineffective contact a professional so they can properly and accurately diagnose the unit for repairs. Unit could possibly have a damaged/cracked tub, a leak in the drain lines, or the water valve.
Dec 05, 2012 | Frigidaire Washing Machines
Frigidaire washer goes straight to agitation and won't fill with water.
IN UNIT THERE IS A SENSOR OF PRESURE WICH HAVE A TUBE FROM WATER CUVA , and when fill water presure high from tub activate membrana and cicle startit ;may there a problem and also at ev . of in water, chec connection and clean dirt but with main out
Nov 04, 2012 | Frigidaire Washing Machines
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
Not draining
the drain pump is separate from the was motor and is accesed from underneath the dishwasher that help wash moter is one piece and is replaced as a whole unit and the drain hose comes from the factory making a loop up side the tub a lot of installers cut the ties holding the loop to get more drain line if loop is removed will loose its prime and stop draining or drain some times and not others when you first start the dish washers it drains then fills so you should hear the drain pump rum if something isnt jamming it
Dec 30, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Washing Machines Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
