Question about HP PSC 1350 All-In-One Thermal Printer
My HP 1350 wont scan
When pushing the scan button, the power - check paper - check cartridge lights all flash... how can I fix this so I can scan again?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Please perform the steps given in the below webpage.
If the issue still persists then power cycle the all-in-one.
Perform a power cycle:
  1. Verify that the unit is powered on.
  2. Remove the power cable from the rear of the unit and wait 20 seconds.
  3. Press and hold the POWER button and insert the power cable.
If the issue still persists then reset the all-in-one.
Posted on Jun 05, 2008
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
I have a HP 1350 that is flashing lights because of a power outage. Computer no longer recognized printer. How do I fix this?
Just logout + shutdown all including power off. Check connections power and cables well. Then first power on printer, then the computer. If the flashing continues then check that your cartridges are not empty.
Feb 11, 2010 | HP PSC 1350v All-In-One InkJet Printer
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP 1350 Says theres a paper jam and won't clear. All lights on.
Try unplugging the printer from power, (Turned off of course) Wait 5 minutes, plug the printer back in. Now open the case like you're going to clear a paper jam, or change ink cartridges. Close the case. Press the Power On button of the printer.
Jun 05, 2009 | HP PSC 1350 All-In-One Thermal Printer
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Feb 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
Problem with HP PSC 1350 All-In-One InkJet Printer
All of the lights flash and it wont print or do anything else. The ink cartriges are new I replaced them right before it happened can you please help?
Feb 04, 2008 | HP PSC 1350v All-In-One InkJet Printer
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
188 people viewed this question
Ben Johnson
