Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
Tweeter not working on 15" EON G2
I bought some used G2s, everything works great except there are no highs from one of the speakers (woofer is fine). Does this mean the tweeter is blown? I see the part is $50-80 online, should I buy and replace or is there a better way to diagnose the problem? thanks
  • 2 more comments
  • Hagman Jun 14, 2008
    I have the same problem, and tested it with my multimeter, and got a reading of 3.8 Ohms, so it looks like my tweeter is okay. What's the next step? Thanks...
  • luckyB Jun 16, 2008
    Thanks for the reply, I opened up the G2 and with my ohm meter set to 20 Ohm range it reads infinite so I image its blown. However using it now compared to the other G2 I noticed the overall performance is pretty muffled, it doesn't get nearly as loud and the red peak light blinks on the "bad" g2 even at low levels. The woofer looks fine and I don't see any burnt electronics inside the case. Could the bad tweeter be related or should I snop somewhere else? These units have very little time on them but maybe were abused before I got them, thanks for any tips!
  • oriongee Apr 13, 2009
    Okay similar problem sound wise (sub works tweeter doesn't). I took
    the tweeter apart and the 'cone' didn't look blown and I don't think it
    is cause it would output something, if at least muffled shrill. The
    next step was to take the Main Amp Board Assy off to look for lose
    connections. I found nothing (granted I'm not to sure what to look
    for). I guess my question is I want to try resoldering the power transistors to the PCB, are they the two big black 63v guys on the inside of the Main Amp Board? Thanks for all the info already guys!
  • 33-third Apr 22, 2009
    I too have no high end to recently acquired EON 15 G2. I checked the resistance across the tweeter, and it was infinity. So I assume I need to replace something in the tweeter. Do I need to replace the diaphragm, are the whole assembly?
    thanks
I had the same problem with no highs from my G2. I initally replaced the HF diaphram and powered it back up and it started smoking and burned out that HF diaphram.
I then found that I needed to replace the whole motherboard assembly as one of the HF chips on the motherboard had blown. Once I replaced the motherboard and the HF diaphram (again), the G2 was back in great working condition.
Wish I had tried ohm-ing out first before I blew the replacement HF diaphram.
So if you don't believe your HF diaphram is blown. I would investigate at the motherboard. I talked to a repair specialist where I ordered my replacement part and he said that those HF components go bad over time. As tough as the G2's are, over time they will need new parts, as the components begin to fail.
Posted on Oct 26, 2008
  • sirwesley Oct 27, 2008
    Try googling this: JBL-EON15G2TUNEUPKIT
  • 515 Answers
Because these speakers get thrown around alot, many people think they are non-destructible - and as such things tend to come loose. So, triple check everything. If something doesn't look right, re-attach it like WAVEFORM did. The larger capacitors that come loose on these models, so look at those as well.
- OPTiC
DJ PRO LAB
Posted on Oct 08, 2008
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Posted on Oct 03, 2008
  • 4,234 Answers
You will need to open up the unit. The tweeter could be bad, there could be a bad connection (1 lead broken or fell off), or the crossover section could be defective.
Lets eliminate the tweet first. Try measuring across the two leads with an ohm meter. It should read about 3-5 ohms. If it reads infinity, the tweet is blown and you need a new one. If you get a reading, post it here and we'll move on to the next step.
Dan
Posted on Jun 05, 2008
My jbl eon 15 g2 smell like burnt and everything works but the big speaker
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
Jan 18, 2015 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
I need to buy a tweeter for my speaker can you help me.
hi,
As it hve a horn tweeter no need to replace the whole unit. You will get the diaphragm. go the following page check the third item. Its the diaphragm for JBL EON 15-G2. An the order code is
DT-004.
http://www.goodhifi.com/MyDias/Diaphragms.htm
ok
Aug 03, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Nov 05, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
Apr 20, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
2,298 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
