Question about Whirlpool Calypso GVW9959K Top Load Washer
Problem After 4 min of use, the washer stop and give a CA error....How can i resolve that....Tahnks
    President:
  • 1,314 Answers
If a status signal comes back from the motor controller that a current limit has been breached,
the unit will return to standby mode and display either “CA” for average current limit trip or
“CI” for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55
Amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading
the unit may cause this problem.
Press STOP/CANCEL to clear the display.
Posted on Jun 05, 2008
Atf600fs0 stops after a few mins on wash cycle
Hello kjgoodwin22 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer
Jan 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite calupso washer starts and runs for 2 min then stops then starts then stops and C1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nutate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Nov 21, 2012 | Kenmore Washing Machines
Calypso washer starts runs for 2 min stops then starts then stops the starts and c1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nut-ate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Nov 21, 2012 | Washing Machines
Stops filling and gives F1 code
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Calypso Washing Machine "Cl or Ca"
The control board is reading too high of an amp draw from the motor,Most likely a bad drive motor.
Sep 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
MY MACHINE GIVES ME A F 11 ERROR AND STOPS
F-11 is communication error between the Motor control unit and the Main CCU. Either of these or both could be bad. Sometimes unplugging all the connections from the CCU (under top panel) and plugging them back in will fix the problem. If fixed, there's a bad connection at the CCU.
Good Luck!
Mar 23, 2009 | Whirlpool Washing Machines
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Have code CA
yep overloaded remove some clothes and consult owners manual for proper load select stop/cancel to clear code if that doesnt work unplug unit for 1 min
Jan 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
prem mathew
