Question about HP 1040 Plain Paper Inkjet Fax
Can't print copies
I did as you suggested, unsuccessful.
Do you have any other possible options?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Can't find the 1st post as to the suggestions so I'll just give you alist of things to check.
Can't print because it comes out blank????
1- original docs are facing the wrong way
2- ink is dry, check the cartridge head
3- try the care & maint. area of the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=02c3572ff6a11ac342ae55fe4e15c1a2&q=hp+1040+fax&e=1
Posted on Jul 15, 2008
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Why can't I print my boarding pass after entering all info?
If you can see the pass on screen you should be able to either copy and paste the graphic into a document to print, or a screen capture / paste/ print might be a second method to print the pass, if you are unsuccessful getting the website dialogue window to cooperate
Sep 13, 2017 | Computers & Internet
It is possible to print 4 photos on one page using S305
if ur trying to print photos
there is option in photos and fax viewer right click print select 4 photos then next select printer next scroll down there is option for 4 page in one
Aug 19, 2013 | Lexmark Impact S305 Wireless All-in-One...
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I can't print scanned material to full size.
You can try the freeware at the link below:
http://www.bestsoftware4download.com/software/t-free-freekapture-download-npbskbaz.html
The description states: "You can also use FreeKapture as an 'ad hoc' copy machine (by using your printer drivers 'how many copies to print' option)."
It works with all twain compliant scanners. Download and install and then point it to your scanner.
Good luck, and please let me know how it works out for you.
Mar 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Problem with keyboard sound control
i) print screen is option that will your current computer screen(in whatever position), when u press print screen an image of screen or current is copied in to your clipboard(cut, copy ,paste) now you have to paste  or copy it in some docu( it is like copying an image......), so now try to open an microsoft applications such as word, powerpint and paste the image in that by pressing ctrl+v or right lick and paste it... youwill an image of you screen.......
and you have to do this which made to think its not working
ii) coming to the volume button:
    sometimes youhave to load software or keyboard drivers that come with the keyboard, try this if not there must be mechnichal failure...
Thanking you
M. Sridhar
Dec 09, 2008 | Compaq Keyboard
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
HP 1040 Plain Paper Inkjet Fax Logo
Seeker5211
Seeker5211
