We have an AKIA 42" flat screen t.v. We have sound but no piture. The t.v. is only one and a half years old.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
6. You may need to replace the convergence IC's, or a larger component on the power board, like MOS switch/bridge/relay, etc...You could also try to replace the whole power board if the above solutions dont help. You can get a service manual from HERE, if you wish, and they will assist you online with repairs and acquiring necessary parts..
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps! If you find that these solutions led you to a fix, kindly take a moment to "Accept" my solution.
Thanks and good luck!
IrishDruid
Posted on Jun 05, 2008
  • 3,037 Answers
It sounds like you need to replace the Inverter/power board and that should fix your problem. Is it flashing on quickly for a split second or anything? Please let me know how this all works out for you. good luck. It should cost you under $200 for parts I would think.
Let me know if you have any further questions and I would be happy to help
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 05, 2008
    Also, I recommend replacing the power supply with a slightly higher rated one so that you don't face the same problem. I believe yours is rated 180W and by replacing it with a 200W, you shouldn't have to worry about this problem which is pretty common on these tvs
  • Benjamin Patri
    Another big thing is that the capacitors go bad very easily on these tvs, they along with the power supply are very easy to replace.
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 4,234 Answers
There are a number of reasons for the symptom that you are presenting here. It would help to know the model number. Also, were there any other symptoms before the complete failure of the picture? Are there any other indications of trouble, like blinking standby lights or other LEDs?
The additional information will be extremely helpful to us to provide you with options and explanations.
Thanks,
Dan
I have a samsung 42 inch flat screen wich has piture in pitur buti carnt get it to work the model number is ps42q7hdx/xeu
To get the pip to work you will need another video source from a vcr/dvd/blue ray hooked up to a video or comp. input in order to get the pip to work.
Mar 19, 2010 | Televison & Video
No Picture on a 4 yr old TV
I would take it to a repair shop, but it sounds like somewhere in the power board.
Nov 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
Black screen has sound akia lct 3201td
hi you must contact akai and let them know your problem if you had your tv less than a year than you are covered
Jan 10, 2009 | Akai LCT3201TD 32 in. LCD Television
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
AKIA LCT42Z6TM
You have the same problem that most people that have this unit do. I had the same problem and fixed it. can fix this, as I have fixed 4 of these units already. Email me if you want more info tommy@ruden1.com
Jul 09, 2008 | Akai LCT4216 42 in. LCD Television
Screen went half black then full black
Sounds like a common voltage adjustment with samsung plasmas,I would call a service center these are things if you dont have experience you shouldnt attempt yourself
Apr 26, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
Haier plasma tv
year and a half old haier plasma 42 inch tv started blinking in and out. is it repairable and how do yo find a technician????? help
Feb 29, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Uhhh I broke my 42 in lcd lg tv on xmas
Ouch, sorry to hear that. I'm afraid there is not much you can do. If you have no warranty plan from the retailer that covers such incidents, you will have to get a quote from a repair outfit. However, my guess is the cost of repairing such damage would not be worth it.
Dec 26, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
