Question about Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9104D my subs fell onto my amp and now won't cut on. The amp lights up but only on the blue part, not the red triangle, when i cut the car on the subs sorda "pop" but then just stay off.
  • clint0 Jun 05, 2008
    my subs fell on my amp and now the subs don't work, everything is hooked up accoring to circuit city. the blue part of the amp lights up but not the red triangle???
    Scholar:
  • 71 Answers
Circuit City ? I'll keep that opinion to myself.
If all is properly hooked up, Check the ground wire for the amp.
Give it a tug where it is connected to the car chassis, NOT the amp,
if it moves or comes loose thats easy to fix, scrape the paint off the grounding point use a high quality ring terminal and a oversize screw with a star locknut. Also check the wiring in the box.
Subs and boxes are quite heavy. And if it's banging around, I hope you have it in a trunk, they are very lethal projectiles in a hatchback should you have a accident.
My second thought is that you may have dislocated a component , solder joint, or cracked the PC board,
When in doubt see a installer. Good luck Sumthin
Sumthin
Posted on Jun 11, 2008
When i turn the music up sub cut off blue light stay on red triangle cuts off
Hi, the amp is going into protect mode. You can either keep it turned down or possibly reconfigure the speaker connections for a higher impedance. If you tell be the model of your sub, I may be able to suggest a better arrangement.
There is a manual here if you don't have one: http://manual.kenwood.com/en_contents/attachDownload/6017/
May 08, 2011 | Kenwood KAC-7204 Car Audio Amplifier
How should i have my 4ohm single voice coil JL audio 12in subs connected to my kenwood kac-9104d 1800 watt max power (500x1 @4) amplifier?
On the outputs of the amp there is:
1 2 3 4
terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Feb 21, 2011 | Kenwood KAC-9104D Car Audio Amplifier
I have a Kenwood KAC-9104D that will power on but not produce any sound??
Be sure the RCA cables are attached and in good condition.
Be sure the remote wire from the deck is hooked up and good.
Be sure the GAIN control is turned up.
Volume on head unit is up. Make sure BASS options are not turned off on deck.
Be sure wires are going the right way. + to + & - to -
Loose wires in the box. Make sure subs are hooked to the terminals inside box.
Check all fuses on amp to determine if 1 or more i blown.
Feb 18, 2011 | Kenwood KAC-9104D Car Audio Amplifier
My kenwood KAC-9104D only hits when i tap the side of it or tilt it at a weird angle.... what do i do?
i had the same problem with the same amp. it was the internal positive terminal on the amp. the connection was bad. i was an easy fix.
Dec 23, 2010 | Kenwood KAC-9104D Car Audio Amplifier
I recently purchased a new Kenwood KAC-9104D 1800 amplifier. I hooked it up just as I had with a previous amplifier but it wont power the subwoofers. When one of the RCA cables is plugged in and the other...
You should check and verify first the output signal in the amplifiers by using a multimeter on the db range, this is to identify good output of the amp. After that check the polarities for correct wire orientations.You should connect the speakers one at a time to check.
Jan 16, 2010 | Kenwood KAC-9104D Car Audio Amplifier
Have a Kenwood KAC-9104D the red triangle is flashing
maybe when hook up something sorted and blew the sub side .I have seen it happen
Nov 27, 2009 | Kenwood KAC-9104D Car Audio Amplifier
KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Jan 13, 2009 | Kenwood KAC-9104D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
154 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
