Question about ASUS VIA KT133A Chipset A7V133-C Motherboard
Upgrading processor to Duron 1.4GHz
I have an old AMD clone with 750MHz processor that I "let" my wife use mainly for surfing and Skype-ing. Motherboard ASUS A7V Rev.1.02 KT133, VIA chipset (VT82C686A), Award BIOS. I have a old but new Duron 1.4GHz processor I bought a few years ago and I am now braving it trying to install it. Piece of cake -- NOT.
When I boot it up with the Duron it goes into some kind of alarm. Sounds like a European ambulance. I thought my research was sound and this chip was compatible, but perhaps my BIOS needs upgrading. If so, to what and more importantly, HOW? Can it be downloaded and installed?
What am I not doing right? Also, how important is a new application of thermal grease? What about the heatsink/fan? Is this chip significantly hotter than the 750MHz?
Thanks for your help!
    Guru:
  • 1,342 Answers
Click HERE and select your specific model motherboard to get drivers and manuals.
Posted on Jun 05, 2008
    Sergeant:
  • 284 Answers
Well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
also make sure the motherboard can actully take a higher processor.
Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
Good luck
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
Amd duron 850mhz
It's a good processor but old enough. The introduction date was Jan-2001 and the price at introduction $149. For todays programs is a bit old. Why do you want to go for a processor like that?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2010 | AMD Duron , 850 MHz Processor
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
Computer hangs when PCI Device Listing comes up
Make sure they are put back in the exact same slots that they came from. If this doesn't work, I can't help you.
Nov 09, 2008 | AMD Athlon , 750 MHz Processor
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
ASUS VIA KT133A Chipset A7V133-C Motherboard Logo
153 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
