Question about Starvision SPF15.2 (Video Kit) Car DVD Player
Star vision pixelon SPF-880
When we put a disc in our car dvd player, it won't play. It just says loading and that it is the wrong disk even though we've tried many discs. Can anyone offer any suggestions?
Why player won't recognise disc
Several things can cause a disk not to read. You could have a bad disc, the wrong type of disc, the disc might not be finalized, the laser pickup could be dirty Try cleaning with a disk cleaner Other problems include bad or weak lasers the spindle motor could be bad ,the disk in detect switch could be dirty. The disk may not be loading into the proper position.These are the more common problems
Aug 07, 2014 | Nesa Vision NSD-790T Car DVD Player
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
Says "No Disc"
If you have put a dvd disk in your dvd player, and it says "no disc" then try cleaning it with a dvd cleaning disk. It could be that the eye of your dvd player is dirty. You can get a dvd cleaner at any department store.
If you have put a dvd disk in your dvd player and its a home made or "burnt" disk and your player says "no disc", it usually means that the disk is the wrong format to be played on your dvd player. Try another disk.
If you have not put any disk in your dvd player, and it says "no disc" its just telling you that there is no dvd inserted for it to play.
Jul 13, 2011 | Sanyo DWM400 DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
How do i fix my CD player? when i put a disk in, the readout says "err disk" it works every once in a while, but i have run a lens cleaning disk in the player, and it wouldnt even read that disk.
how long have you been using the player? And has it been giving you this type of problem before now?
I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
Good luck.
Sep 25, 2010 | XO Vision XO9013 Car DVD Player
Dvd wont play says wrong disc
If this happen with all disks , then the lens are dirty or faulty.
Try cleaning the lens with a cleaner DVD. If that is not enough, then the player must be taken apart to clean lens with isopropyl alcohol and cotton, or to replace the lens pickup.
Before attempting repair call manufacturer or retailer to check warranty status.
Sep 10, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
I have a remote diamond vision vcr/dvd
if yours plays DVD's I will take it off your hands.
The one I bought from Walmart has never played one disc. Always says wrong disk. Factory set for region 1 and I live and bought it in region 2.
Jul 13, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
"wrong disc" message
Since the device is new, I suggest that you take it back to the shop, ask for a replacement and check it while in the shop to make sure its working. This is assuming that you made sure that you're trying to play the correct format discs. Consult the manual on which format DVD's it can support. Its multi-region so that can't be the problem, but its possible that you're trying to play other unsupported formats. Try also playing other discs - audio discs, DVDs, DIVX etc... make sure the disc isn't scratched badly. But the bottom line is you shouldnt have problems on the first day, take it back. Good luck!
Jan 25, 2006 | Yahoo Diamond Vision DVDC803-04 DVD Player
Starvision SPF15.2 (Video Kit) Car DVD Player Logo
71 people viewed this question
Top Starvision Car Audio & Video Experts
xxxxxx xxx
Are you a Starvision Car Audio and Video Expert? Answer questions, earn points and help others
