Question about Dell Dimension 2400 PC Desktop
How to install a new dell 512mb memory chip so that it gives me 1 gig
Basically like the subject how do i go about installing the 512mb chip so i upgrade my memory to 1 gig
Need help email me drummernick2002@aol.com live help thx nick
need low density ddr ram
Posted on Jun 08, 2008
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Continual reboot with second memory module
Your memory isn't an exexact match. The 512MB you have in is probablyis Kingston, part # KT3311/512, PC2100/2700, 512MB DDR. You should get Kingston part # KT3311/1G, PC2100/PC2700, 1 GB DDR. You can use another manufacturer but everything must match exactly execpt the size of course. The speed, DDR, everything. Make sure you have the new chip seated correctly and in all the way first. Of course if it doesn't match the specs of your other chip it won't matter. Best thing to do if buying locally is take the first chip with you. If not buying locally, have it with you when you order to make sure it matches.
Mar 29, 2008 | Toshiba Satellite P35-S605 Notebook
Ram memory upgrade
1 gig is the max. Get two sticks of 512mb kingston. If you go to kingston.com you will see ways on how to find the optimized RAM for your computer. If i am correct here are the specs for the ram that you need. 512MB-DDR333 PC2700, 184p DIMM, 2.5v, Sync, CL=2.5
Feb 25, 2008 | Areca ARC-1210 Serial ATA Controller
Dell Inspiron 1100 does not see new memory
Install one memory first to any of the memory slots and boot your laptop... then do the same on the other slot with the same memory.
Now do the same step to the other memory...
That is to see if any of the two memory has a problem or to see which memory slot has a problem... You should find a problem in there... that would be memory or the memory slot.
Jan 25, 2008 | Dell Inspiron 1100 Notebook
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Dell Dimension 2400 PC Desktop Logo
60 people viewed this question
Alun Cox
