Question about Goodman CLQ36AR49 Air Conditioner
Goodman air conditioner not running
I noticed that not so cool air was blowing out of A/C vents. I went outside to check on a/c unit to find only one was running. Looked at lines to house and noticed no leaks or frost. i dropped the temp on thermostat to try and kick it on but it didnt work. Unit next to it for upstairs seems to run fine. I also checked breaker to see if it was tripped but it was fine. Units are only 3 yrs old. Any suggestions?
2 summers ago, exact same problem with one of our two units outside. contractor that installed the unit when home was built was not helpful and not able to come out. another a/c company explained they would not be able to make it that day, but offered knowledge that often times in my area (San Antonio, TX) ants get into the electrical contacts of the mechanical switch and block the current.
following instructions to trip all the breakers inline and checking this it was confirmed, i cleaned the contacts with pencil erasers (a trick i learned with model car electric leads) and sure enough it's still working 2 years later.
believe it or not the same year my water well had the same symptoms and it turned out to be the mechanical switch was blocked by ants also!
Posted on Jun 05, 2008
Air conditioner isn't blowing cool air and it's not coming out of the vent very fast
Check to see if air is blowing out the back side of condersor,outside ,maybe fan not blowing on outside, or freon low.
Mar 17, 2015 | Goodman Heating & Cooling
Goodman GPH1336H21A
If the power failure was due to a storm the blower motor may have shorted out. Check that the breaker for the inside unit has not tripped.
Jul 05, 2014 | Goodman Heating & Cooling
My a\c unit not cooling but the unit is running
check to see if the fresh air vent is blocked. If the unit is outside make sure nothing is blocking the air flow ie. grass, weeds, etc.
If these are clear, you probably need some "freon"/ coolant installed.
Jul 13, 2012 | Goodman CKL24AR24 Air Conditioner
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
I had power blink off for a couple of seconds and then came back on. The Amana air conditioner RCC30A2E seem to be On but no cool air was blowing. I check breaker it was ok. I preceeded to check...
Check for fuses in the 24v wiring. Was anything running outside? The 24V X-former is located in the air handling unit. check for voltage on the air handler. if present, check output voltage at X-former. You should have 24V
Oct 14, 2009 | Heating & Cooling
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
No cool air
turnn unit off and allow to unfreeze.
if it happens again you need to have a service check refrigerant pressure in your unit.
regards
Sep 10, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
231 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
