Question about Maytag 24 in. DWU9202 Built-in Dishwasher
Soap dispenser The soap dispenser door does not open automatically as it should... stays closed throughout the cycle unless we stop the cycle, open the dishwasher door and then open the soap dispenser door any suggestions? This is a Maytag DWU 9200.
  • 525 Answers
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 04, 2008
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap door will not open
Chaney,
Make sure there is nothing in the way of the soap door when you close the dishwasher.
Close the dishwasher door slowly and look down in side with a flashlight, are any of the rack brackets or silverware basket directly in front of the dispenser door.
Take a look and let me know.
Regards.
Jul 21, 2009 | Frigidaire Dishwashers
The soap isn't coming out of the soap dispenser during the wash cycle. when i open the dishwasher door the dispenser opens with all of its contents still sitting there!
I had the same problem once. Make sure nothing is stacked in front of the soap dispenser when you close the door. Slowly close the door and follow the soap dispenser to make sure it has enough clearance to open.
Let me know how it goes.
Regards,
Jul 19, 2009 | Electrolux Kenmore 24 in. Built-In...
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Dishwashers Logo
474 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
