Question about RCA D36120 36 in. Rear Projection Television
52" rear projection panasonic
I have a blue ghosting effect i tried to do all i can with the remote but no such luck. What can i do? Im pretty good with electronics and have a friend who is alot better that can help. just fyi there. Thanks for any help.
  • Yeah_T0ast Jun 09, 2008
    Its PT-51HX1E . Anything else that can help you help me just ask.
    Thanks Brian
  • 80 Answers
Model number # please
Posted on Jun 09, 2008
My lg rear projection tv is showing the red green and blue ghosting on the pictures making them distorted ,they are all side by side, the colours sre all there but the picture looks as if its on three...
3D effect caused by failing convergence chips on the internal control board. You will need professional intervention to repair or replace this board or the chips. Often this is in association with other parts that need attention and is not a DIY.
Please rate our help++++Thanks for using FIXYA
Oct 08, 2009 | LG RU-52SZ51D 52" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Tv keeps changing channels on its own and remote not working
I disconnected the front buttons of my set. Pop off the speaker cover and note which color wires come off the buttons and then take off the lower back and you can see where it connects to a board. Generally the far right connection but trace the wires. After doing that my channels quit cycling and everything but the front buttons work.
Mar 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Blue ghosting
This could be a convergance problem, if there is such an adjustment described in the manual and it doesn't work, make sure the optics are clean.
Oct 06, 2007 | RCA P52929 52" Rear Projection Television
Skt IC and Capicitor??
You need to replace both STKs. They are pretty obvious to find in the unit. They are normally mounted to the same heat sink and will typically be about 3 inches long each, maybe 2 or so high...Front should read something like STK350-120
Feb 07, 2007 | Panasonic PT-61HX40 61" Rear Projection...
Rca 52' projection convergence problem
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
May 22, 2006 | RCA P52926 52" Rear Projection Television
RCA D36120 36 in. Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
