Question about Toshiba 57H81 57" Rear Projection Television
Could you tell me how to get into the service menu of my toshiba rear projection tv?
The green convergence on my tv is making the picture look like the right side is doing a wave.  I can get into the convergence portion on the menu but that only takes care of the red and blue setting.  However, it is the green setting that is not right.  I accidently pushed the touch focus button on the front panel...and it seem to through it off....Did this a couple of weeks ago and had a service person come out and fix it.  He went into the service menu, but I do not know how he got there.  Any help would be appreciated.
  • connienjim Jul 24, 2008
    Our problem is identical. Bought the Toshiba 57H81 Dec 2001 and this is the first sign of a problem. Any advice on getting the green to converge is appreciated.
    Scholar:
  • 87 Answers
Most TV repair shops have a warranty 30, 60, or 90 days. Call him back. You probably have a convergence IC failing or a resistor changing value in the green convergence output circuit.
Posted on Aug 03, 2008
I have a Toshiba 57H82 rear projection tv. It has colored wavy lines on the screen and no picture.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 19, 2011 | Toshiba 57H82 57" Rear Projection...
Picture started flashing like 3-D in the hd ed mode
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Toshiba 57HX81 57" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
Words ars doubled and arching, green and purple across parts of the screen, picture blurred
  • Screen looks 3D
69189a5.pngSOLUTION
Dec 26, 2010 | Toshiba 53HX71 53" Rear Projection...
Picture appears to be 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
Fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
*Screen Looks 3-D
*Colors wont align
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
Toshiba 50h81 2001 rear projection hdtv ONLY SHOWS GREEN! PLEASE HELP!
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
