Question about Whirlpool Duet GHW9150P Front Load Washer
No service manual
whirlpool duet, model GHW9100LW1
Series CSP3811762, type, 199.
  • Lorraine Lor Jun 09, 2008
    machine starts filling up with water and after 1 min stops, locks itself and the F and H flash. We have reset the machine and try again only for the same thing to happen.
  • 487 Answers
Water filters in the hose attachment at the machine cloggs up. Sometimes fast. take off hose and clean the filters.
This is from whirlpool:
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component.
Posted on Jun 08, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
FH error code frustration
Replace main control board and pressure switch together .
May 26, 2013 | Whirlpool Duet GHW9150P Front Load Washer
FH Error code Whirlpool Front load washer. I
the only thing you can do is to go to the manufactures website and download the user manual and check the trouble shooting guide for a possible cause for this problem eric
Jan 17, 2018 | Whirlpool Duet GHW9150P Front Load Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
  1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
  2. FH Error Code
  3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
  4. FL Error Code
  5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
  6. F02 Error Code
  7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
Dec 06, 2010 | Kenmore Washing Machines
Error code FH on my AWM, what does it mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
Getting an FH error code during the cycle count down
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
Fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Jan 26, 2008 | LG WM1814CW Front Load Washer
Service manual
I want user manual for cannon imagerunner 400 / 330 series
Sep 19, 2007 | Canon imageRUNNER 400S Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal De
