Question about Kenmore 22422 Top Load Washer
Water is leaking from the underneath, at the front of the machine
I accidentally washed some tiny rocks (in my son's pocket) and now my washer leaks at the front, underneath.
  • 413 Answers
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Posted on Jun 04, 2008
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Leaks underneath
most likely the drain pump,its located behind the front panel and the center seal on these leak after time,very easy to replace
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Unbalanced Load no matter how many items in it.
With the washer not running, try rocking the machine from left front to right rear and then from right front to left rear. The machine should feel exactly the same both ways. If you feel any difference in stability between the two directions, adjust the right front support until there is absolutely no difference in the feel when rocking the machine l-r and r-l. (even a tiny difference will allow the machine to rock when spinning.
Jan 30, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Leaks water underneath ..repair man said there was pin hole in hose underneath and needed new hose..are they over 100 dol to replace? Doest seem a tiny pin hole could cause that much water to flood out.
If you can locate the pin hole then when the machine is dry block the pin hole by putting araldite glue paste and let it settle for sometime. It should solve your problem.
Mar 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washer leaking from underneath
MY FIRST THOUGHT WOULD BE INSPECT THE BIG GREY DOOR GASKET FOR A CUT OR A TEAR. LOOK CLOSE. THE WHOLE MAY BE TINY
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Dec 11, 2009 | Westinghouse Washing Machines
I HEAR A RATTLE WHEN THE MACHINE IS IN SPIN CYCLE. IT SOUNDS LIKE SOMETHING IS UNDER THE BASKET.
Do you have kids? My sons were bad for putting things in their pockets. Rocks, sticks, nails. Anything they were fiddling with outside. Many a times a small pebble or small nail would slip through the holes and make 'music'.
Now they are teenagers and when I do laundry I tell them if I find money in the machines it is mine. Guess what? They check their pockets good! XD
Sep 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from underneath somewhere. How do I get it apart to find the leak?
best way is to tilt it a bit (with 2x4 or something) when it starts leaking, find out whats leaking with a mirror and flash light some times hoses have tiny holes that leak,
Jun 26, 2009 | Maytag Legacy Series Top Load Washer
Kenmore 22422 Top Load Washer Logo
516 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
