Guitar amplifier sound
When I turn on my marshall amp it makes a strange sound which resembles a small motor. it has only started making this sound recently, before now the amp was silent. the sound on the amp is good but it just makes this weird noise. can you help me?
  • thecross Jun 16, 2008
    The model of my amp is Marshall Valve State 2000 AVT. And it is a 50 watt amplifier.
    Please help me if you can. Thank you very much.
  • 1,512 Answers
HI thecross
What model Marshall have you got?
regards
robotek
Posted on Jun 06, 2008
  • Graeme Ross
    Graeme Ross Jun 17, 2008
    Hi thecross
    Marshall Valvestates have problems with dry solder joints making them do many things from howl, to distort, to not work at all. Your amp has probably fallen to this problem also. If you can solder, i suggest removing and resoldering the main pcb. This will sort out 90% of its problems.
    regards
    robotek
When I use the over drive effect channel the head makes a rapid beeping sound.
Make sure your guitar cannot "hear" the amp as the guitar can be a pretty good microphone to cause feedback. Feedback sometimes saturates an amp and causes "squeging" which is a cycling into and out of feedback.
Apr 22, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
Hello, well i just bought this week an MB4410 marshall and it sounds a lil bit distored even at low volumes and on the clean modern channel, i just wanted to know if thats how the amp should sound like or...
First make sure your guitar can't "hear" the amp as the sound can rattle the strings and have a form of feedback. Stand with your back toward the amp for example. If that doesn't help, take your guitar to the dealer and try it on another of the same type... see if it does the same. Also where you use it, make sure nothing is rattling in the area that can fool you as to how it sounds...
Apr 10, 2011 | Marshall MB4410 Bass Combo Amplifier
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Amp Sound Problem
try cleaning the send and return sockets with switch cleaner or WD40
Jan 31, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Guitar amplifier
Hi thecross
I have fixed so many of these amps over the years... Marshall Valvestate series of amps are notorious for dry solder joints developing on the main PCB. If you have the skills(or an old mate that does)Remove the PCB from the chassis and resolder any suspect dry joints and you will fix the problem. Check particularly about any components there the PB has changed colour. This is an indication of heat in that area, and heating and cooling is a major cause dry joints.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 16, 2008 | Audio Players & Recorders
Amplifier sound difficulties
When I turn on my marshall amplifier its makes this unusual, anoying sound. it sounds like a small motor or a fan going. the sound of the amp is good but its just makes this motor sound when I switch it on. can you help me find the problem.
Mar 25, 2008 | Prime 40 Watt 2 Channel Lead Electric...
100 people viewed this question
 Grubhead
Grubhead
