Question about HP OfficeJet d145 InkJet Printer
Cartridge jam My d145 carriage jammed. Did everything to correct and ultimate found a piece of mechanism at right side of interior of machine loose. No idea how to reconnect this piece (see pic)- has four, hinged, clawed feet to hold in place. Two are connected and front two off- but no idea where they go. Thank you- Bob
  • Ramnyc Jun 23, 2008
    Thank you.. did my best but could not get it back in. I ended up finding a replacement ink station on Ebay ($20.00) and it came with directions to disassemble the machine (vital)... got it back up and running. Thanks.. Bob
There are clips under the feet, get a torch and u can align them both and push down at the same time, they will click in. To test it make sure there is only frontal and backward motion, one is out still if it moves side to side.
Posted on Jun 06, 2008
C5180 jam in carriage - removed paper but not printing
Check at the cartridge end of the machine. I found a piece of paper jambed in that kept the carrige from parking on the right side. I had to turn off printer. take the paper trqy out and turn the machine on it's right side and use a flashlight to find it and get it out.
Dec 31, 2014 | HP PhotoSmart Office Equipment & Supplies
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
My printer carriage has jammed.
To resolve the issue, you can try each solution in this document in the order presented.MPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware functions correctly. To print a self-test report, use the steps in the following table:Load plain white paper into the input tray.Press Setup on the product control panel.Press the right arrow ( ) to select Print Report , and then press OK .Press the right arrow ( ) to select Self-Test Report , and then press OK . The self-test report prints.Solution one: Turn the product off and on again Follow these steps to turn the product off and then on again to reset the printing mechanism Press the Power button to turn off the product. If the product does not turn off, continue to the next solution.Wait 60 seconds.Press the Power button to turn on the product NOTE:The product might go through a warm-up period. The product lights might flash and the carriage might move. Wait until the warm-up period finishes before you proceed. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution.Solution two: Clear any paper jam Follow these steps to clear any paper jam.Step two: Clear the jam from the rear of the product Use one of the following methods to clear the paper jam from the rear of the product. If your product has a two-sided printing accessory (duplexer), skip to Method two.Method one: Clear the jam from the rear access door Press the Power button ( ) to turn off the product, if it is not already off.Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the rear access door: Press the tab on the left side of the door inward, and then pull the door out.Figure 1: Remove the rear access door ently remove any jammed paper from the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 2: Remove torn pieces of paper from the rollers Reattach the rear access door. Gently push the door forward until it snaps into place.Method two: Clear the jam from the two-sided printing accessory (duplexer) Press the Power button ( ) to turn off the product Disconnect the USB cable from the rear of the product.Disconnect the power cord from the rear of the product.Remove the two-sided printing accessory (duplexer) from the rear of the product: Press the buttons on each side of the duplexer, and then pull it toward you. Figure 3: Remove the two-sided printing accessory Gently pull the jammed paper out of the rollers.CAUTION:If the paper tears while you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.Figure 4: Remove torn pieces of paper from the rollersIf you do not see jammed paper in the rear access area, push the latch on the top of the duplexer, and then lower its cover.Figure 5: Open the duplexer - Latch on top of the duplexer Duplexer cover Remove any jammed paper from inside the duplexer.Close the duplexer cover, and then reinsert the duplexer into the rear access area of the product. Figure 6: Reinsert the duplexer Push the duplexer inward until it clicks into place.Step three: Clear the jam from the front of the product If you cannot remove the paper jam from the rear of the product, follow these steps to remove the paper jam from the front.Open the cartridge access door.Figure 7: Open the cartridge access door NOTE:The carriage should be on the right side of the product, out of view. If it is on the left side, close the cartridge access door, and then turn on the product. Unplug the power cord from the wall outlet, and then open the cartridge access door again.Look for any pieces of paper or other debris inside the cartridge access area.Gently pull the paper out of the rollers.CAUTION:Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.Close the cartridge access door.Figure 8: Close the cartridge access door Reconnect the USB cable to the rear of the product.Reconnect the power cord to the rear of the product.plug the power cord back into the electrical outlet. Press the Power button ( ) to turn on the product. Reload paper in the input tray.try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.If the issue persists , continue with the next solution.If the self-test report does not print , continue with the next solution.Solution three: Make sure the carriage moves freely Use the following steps to make sure the carriage moves freely.Press the Power button ( ) to turn on the product, if it is not already on.Open the artridge access door.Figure 9: Open the cartridge access door Without turning off the product, disconnect the power cord from the rear of the product.WARNING:You must disconnect the power cord to move parts by hand without the risk of an electrical shock.unplug the power cord from the wall outlet.Look inside the product to see where the carriage is stuck, and then check for any torn paper or other objects that might restrict the movement of the carriage.NOTE:You might need a flashlight to illuminate areas inside the product Figure 10: Use a flashlight to see inside the product Remove any loose paper or obstructions you find.Figure 11: Example of obstruction in carriage access area Reach inside the product through the cartridge access door, and then manually move the carriage. You might have to reach through the paper output tray to access the carriage.If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.Make sure the carriage moves freely across the width of the product by gently pushing the carriage to the left, and then to the right.Close the cartridge access door.Figure 12: Close the cartridge access door. Reconnect the power cord to the rear of the product.Plug the power cord into the wall outlet. Press the Power button ( ) to turn on the product. Try to print a self-test report. See the steps on how to print a self-test report at the beginning of this document.If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. four: Remove and reinstall the cartridges Improper placement or installation of the cartridges can cause the product to indicate a carriage jam error.
Oct 12, 2011 | HP Officejet 6500 Wireless All-in-One...
Turn printer on ERROR comes on screen. Carriage jam Open Door clear carriage jam and then press OK to continue. I do this nothing found in carriage close Error comes up the same?? What to do?
Joe,
Pull all of the paper out of the machine. Look for a wadded up small piece of paper. After you look for it. Examine the door slide tray where paper is stored. Look at take-up rollers... make sure slide drawers close easily...examine door where print cartridge is....Look at (on side) feed tray...Paper feed tray... If you fail get a flashlight and take another look it does not have to be a very large piece of paper...good luck
Nov 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
My hp laserjet 2430 keeps showing paper jam on tray 2 but no paper jam there. I have to press the ok button always to proceed. what could be the problem
Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the rear of the product.
    Remove the rear access door. Press in the release tab on the rear access door, and then pull the door away from the product. Figure 2: Remove the rear access doorc00909313.gif
  • Gently remove any jammed paper or bits of torn paper from the rollers inside the product. Use both hands to pull any whole sheets of paper to avoid tearing them.
    CAUTION: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur.
  • Check the rollers on the rear access door. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  • Open the cartridge door.
    Without turning off the product, disconnect the power cord from the back of the product.
    CAUTION: You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  • Disconnect the power cord from the wall outlet.
  • Look inside the product to see where the carriage is stuck, and then check for any torn paper or objects that might be restricting the carriage.
    NOTE: You might need a flashlight to illuminate areas for proper viewing.
  • Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product , move the carriage to the right side of the product.
  • Remove all traces of paper or obstructions found.
  • Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left side of the product, and then to the right side.Close the cartridge door.Reconnect the power cord to the back of the product.Reconnect the power cord to the wall outlet.Press the Power button (c01602202.gif ) to turn on the product.
  • Nov 11, 2010 | HP LaserJet 2430dtn Printer
    The printer is constantly sending a message- 'paper jam'
    HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
    Issue
    During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
    Solution
    Use the following instructions to clear a paper jam from the product:
    Step one: Check for and remove any loose paper from the In tray
    Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
    CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
    Step two: Clear the jam from the back of the printer
    Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
    Remove the rear access door to clear the paper jam
    1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
    Figure 1: Removing the rear access door
    Rear access door
    2. Gently pull the jammed paper out of the rollers.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
    3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
    Remove the two-sided printing accessory to clear the paper jam
    1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
    Figure 2: Removing the two-sided printing accessory
    2. Gently remove any jammed paper.
    WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
    3. Press the button on top of the two-sided printing accessory to open the door.
    Figure 3: Opening the two-sided printing accessory door
    4. Gently pull the jammed paper out of the rollers.
    5. Close the accessory door.
    6. Reinstall the two-sided printing accessory.
    Step three: Clear the jam from the automatic document feeder (ADF)
    1. Remove the document feeder tray from the product by gently pulling it.
    2. Lift the cover of the automatic document feeder by pulling it outward.
    Figure 4: Lifting the cover of the automatic document feeder
    Automatic document feeder (ADF) door
    3. Gently pull the jammed paper out of the rollers.
    WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
    4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
    Step four: Verify that the print carriage can move freely
    Follow these steps to try to move the print carriage.
    CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    Step five: Reload and test the printer
    After you have removed the jammed paper, make sure the product is still functioning properly.
    1. Reload the product with plain paper.
    2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
    Step six: Service the printer
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Dec 30, 2009 | HP DeskJet 3745 Printer
    Carriage jam
    Step 1: Move the carriage to the center manually if necessary If the carriage is stuck on the right or left side of the product, follow these steps to move the carriage to the center of the product.
    Step 2: Check for a broken carriage chute
    The carriage chute is the side wall of the carriage that holds a curved metal piece (the x-bias spring). A broken carriage chute might cause the carriage jam condition.
    Step 3: Turn the product off and on again
    Step 4: Clear any paper jam.
    Step 5: Make sure that the control panel faceplate is correctly installed
    Step 6: Plug the All-in-One directly into a wall outlet
    Step 7: Perform a partial reset
    Step 8: Print a self-test page
    Step 9: Service the product. Now this model is outdated as per HP website.
    Aug 23, 2009 | HP Officejet 7210 All-In-One InkJet...
    Epson R320 carriage jammed
    The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
    Remove it and reinsert it, making sure that it is fully located, before applying the power.
    Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
    Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
    Carriage Jam
    I tried all these steps and it still did not work was ready to throw the printer out from frustration. Instead I traced what I did when I had the jam. I believe if the factory can fix it so can I. My printer is now working and it was so simple yet HP does not tell you how to fix it.
    Jul 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    HP OfficeJet d145 InkJet Printer Logo
    37 people viewed this question
    Ben Johnson
