Question about AMP (219560-5)
Immeadiatly shuts down
Hello this is a memphis pro 1000.1 car amp the green light come`s on for a sec then shuts off but the fan in side keeps runing..but i`m not geting any sound?
thanks
  • victorcepeda Dec 13, 2008
    hi i have a memphis 1000 watts mono amps and i just installed an d it works for like 10 minutes or a little bit more and shuts down to the red light and again i start the car and amp works a little bit and again shuts down what can i do
    Genius:
  • 1,550 Answers
First disconnect the speakers and check if the amp. stays on.If don't your audio amplifiers IC's are in bad conditions.Good luck.
Posted on Jun 05, 2008
I have a memphis mcd 1000. It started smoking and blew both fuses. I replaced the fuses now when I hook power to the amp sparks real bad like the power and ground are touching
I hate to tell you this, but you have something major. Shorted. Check your wires and conections with a meter. The bad news. Is your amp may be a goner.
Apr 28, 2015 | Memphis Car Audio & Video
Low independence light comes on and a humming sound what is causing this?
Humming from subs? If from inside amp, your experiencing a problem with a driver board. It makes transistors latch on and loads down the transformer, causing light to come on. And vibrations "hum" from transformer.
Oct 16, 2012 | Jl Audio 500/1V2 Car Amp
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
How many different ways can you wire a 12 memphis subwoofer
you need conneciton to amp streit from battery terminal but make sure you put an inline fuse in the main wire first for safty
Oct 07, 2009 | Car Audio & Video
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
My amp turns on, power light is on, but overcurrent light also
make sure ground is good then turn gain all the way down turn on deck turn it all the way up then turn it off then back on agian its like a jump start the amp then should work and you can reset all youre levels
Apr 08, 2009 | Car Audio & Video
Smart pro keeps shutting down
it seems that the internal battery is bad, even if it is new but if it stays in the shopping store for long time it may become bad and not charge.
Dec 09, 2008 | Tripp Lite Smart Pro UPS System
My amp overheats..
Do you mean that it actually over heats and shuts down? If it does then make sure you aren't trying to over drive it or underdrive the impedence. A good suggestion for cooling is get some 1/4" spacers and space the amp up off of the surface you mounted it too. I did it when I had my 2 Memphis M-Class 500Ws and just doing that they were cooler. Also make sure it is not mounted in a restricted air flow spot. If it is put some cooling fans by it to circulate some of the air. Let me know if you need some more help. Good luck.
-Andrew Hawkins
Apr 25, 2008 | Kenwood KAC-X650D Car Audio Amplifier
Computers & Internet Logo
96 people viewed this question
Top AMP Computers & Internet Experts
NOEL
NOEL
richie46
Tom Chichester
Are you an AMP Computer and Internet Expert? Answer questions, earn points and help others
