Question about Lexmark X83 All-In-One InkJet Printer
Uninstalled printer I accidently uninstalled my printer and I do not have the original installation disk for my printer. Can I reinstall it from the internet?
  • 65 Answers
You sure can. Here is a link. Click HERE
Posted on Jun 05, 2008
Have lost ability to scan or copy
Do you have your original install disks? Go to Control Panel, Programs and uninstall the old stuff. Then just reinstall the new. If you don't have the original install disks, go to the printer manufacturers website and download the new drivers and install them.
Aug 18, 2013 | Office Equipment & Supplies
Failed to create print object...The specified port is unknown (1796). I have uninstalled my printer and am trying to reinstall from the original install disk. I get nearly thru the entire process and...
To me it seems that the uninstallation proagram did not fully uninstall the printer. Can you first try this guide http://www.fixya.com/support/r5071075-windows_manual_printer_removal to make sure the printer is fully uninstalled. Once you have completed the guide, remove the printer from the computer and reboot it. Then try installing the printer and plug the printer in when the installation asks for it to be connected.
Jan 23, 2011 | Dell Office Equipment & Supplies
I somehow uninstalled the Dell Imaging Toolbox for my V305 printer. How do I get it back?
I cannot find a separate software download for the Imaging Toolbox. I can only assume it comes with the driver itself when installed.
If you have the disk for the printer, uninstall the printer software you have already installed using the Add/Remove Programs from the Control Panel. Restart your computer and look under the Start>Printers and Faxes and make sure it is not listed.
disconnect the USB cable from either the computer or printer and insert your disk and install as you did originally. Connect the USB cable when prompted.This should reinstall the driver and Imaging Toolbox.
If you do not have the disk, you can download the software from the Dell website at:
Dell V305/305w Driver
Download the software to your desktop. Uninstall the previous software...reboot...then double-click the file on your desktop.
Hope this helps. If you have further questions, just use the Comment link.
Thanks for using Fixya.
Dec 11, 2010 | Dell V305w All-In-One R840635AU InkJet...
Software won't fully install
Before connecting the printer to USB port, install software which is came along with the printer. Inbetween it will ask you to connect the printer for detection and install the respective drivers for that printer.
Dec 15, 2009 | HP PSC 2175 All-In-One InkJet Printer
Reinstalled zebra printer on different computer
the printer is set to the wrong mode, do a reset on the printer to default settings, or factory reset, but you could have installed the wrong drivers for your printer from the install disk you got if it was working before you installed them, so uninstall and let your computer automatically install standard drivers for it or if you need to install the exact drivers, do just that from the install disk, make sure you know exactly the model of your printer
Jun 29, 2009 | Zebra LP 2844 Thermal Printer
Says I need to reinstall drivers
TRY:
http://admin.utep.edu/Default.aspx?tabid=56
Downloading and installing.
Remove printer from 'printers & faxes'.
Uninstall printer software from 'add & remove' programs.
Disconnect the printer from your computer.
Reboot your computer.
Install the printer software that you downloaded. Connect printer to computer following on screen instructions.
Jun 08, 2009 | Lexmark X1150 All-In-One InkJet Printer
HP2601xi says I need software when I push the scan button
Uninstall the printer then reinstall it. the software went bad,biut it wil have to uninstall first. The other option is to disconnect and uninstall within windows itself, the reinstall.
Feb 16, 2009 | HP Photosmart 2610xi All-In-One InkJet...
To reinstall Epxon C64 the driver doesn't install.
Hi dorothy - it seems you're having a few problems, but it's not clear from you post what the problem is. You can't "update" this driver, you must un-instalI before you re-install. I suspect you now have a very confused driver installation. The easiest way to get over this is to do a Windows XP system restore to a date before you first tried to update the driver. Once you have done this you may uninstall the original driver (use the Control Panel to do this) and install your updated driver. But don't do this unless you really need to. Why were you trying to update the driver in the first place?
If a system restore is not possible, try the following procedure. Click on start-control panel-printers and faxes. Do you have more than one copy of the printer installed? If so, we will uninstall all of them. But FIRST, make sure there are no jobs left in the print queue. Double-click each printer icon in turn and delete/cancel all print jobs listed. Then delete each "copy" of the printer (right click-delete the icon) except for the original one, which you uninstall using the Control Panel-Add/remove Programs-Epson Printer Software. After you have done all this, turn OFF the printer, reboot the computer and then re-install the printer. Make sure you keep the printer turned off until the installation program asks you to turn it on.
If none of this helps, or you want further information, please report back. If this advice has been of help, please rate it.
Jan 13, 2009 | Epson Stylus® C64 InkJet Printer
Need Help With Printer...
1. Insert the printer software disk and follow the prompts. or 2. Go to Start/printers and Faxes /click on install new printer follow the prompts. or 3 Go to Start/printers and Faxes /click on install new printer and when you get CD or List select List -then make then model.
Sep 08, 2007 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
