Question about JVC RX-6042 Receiver
Overload keeps going in too overload when turned on with nothing hooked up too it overload flashs on the front screen
    Genius:
  • JVC Master
  • 1,550 Answers
The audio amplifier IC of your device are damaged you gotta send to a repair center.
Posted on Jun 05, 2008
Its it's a Panasonic receiver sa - xr15 it keeps on saying it's overloaded and I got nothing hooked up to it right now
It might be down to the fact that the main power amp has shorted and therefore overloading the system. It can happen if say you had some faulty speaker cable, or two wires touched together. Or it can happen on it's own.
May 14, 2016 | Panasonic Audio Players & Recorders
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
Overload keeps flashing
Remove anything that may be sitting on top of it, and give it at least 6" of clearance all the way around it to help dissipate heat and leave it that way
permanently.
Next check that the speakers you are using have a compatible Ohm rating for the receiver.
Dec 19, 2009 | JVC RX-558V
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
My denon receiver keeps shutting off around -15 and it just started doing it. I reset it to factory settings and all the speakers are working fine. It isn't hot, it will do it as soon as I turn it on. I am...
try this and see if it work. keep in mind that the audio output is very sensitive unit and it has a built in reset switch which keeping the unit from shorting out. the systems go into reset because of safety precaution overloading the systems. The most important is to make sure you have the correct post connect from the receiver to the speakers, such as Positive to Positive and Negative to Negative. If the post is not hooked into the correct post it will sense the overload and the unit go into reset mode or protection mode. Trace the correct wire to the right post and see if that will rectify the issue.
Dec 02, 2009 | Denon AVR-1908
Overload flashs
there will be 6 amp circuit in your receiver. you can't unplug them one by one. with a multi-meter you may be able to find the shorted channel. (most JVC receivers use discrete circuits instead of an output IC) Check for shorted transistors attached to the heat sink. You will possibly find some open resistors also. Generally this is a job for a pro.
Feb 26, 2009 | JVC RX-6042 Receiver
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Powers on regular to total green screen,light flashes 6 times
the +5V line is either shorted or overloaded on the A & B board I reccomend a qualified tech do that repair unless you feel comfortable doing this but you will need a service manual for your set if you dont have one please let me know I can post a sight where you can get one with free online tech support
May 06, 2008 | Sony KP-51WS520 51" Rear Projection...
Red x on my tomtom go one
Tomtom GO 910 GPS Receiver flashing white X in a red circle
I discovered that there was a file on the 910 called CLMDATA which was corrupt. When I deleted this in Windows explorer, the unit started up and worked OK. This file is recreated when the unit starts up
Oct 28, 2007 | Tomtom GO 910 GPS Receiver
JVC RX-6042 Receiver Logo
620 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
