Question about Yamaha HTR-5630 Receiver
Immeadiatiy shuts off
When you turn it on with nothing hooked up too it it immeadiatiy shut off?
thanks
  • Anonymous Jun 30, 2008
    stays on for 3 seconds then shuts down
I think your unit have a problem with the ic amplifier STK 402 or STK 404because there are 2 stk ic in hrt 5630, you must have an electronics background to identify witch one is defective,, i have the same problem b4 and i change the big one STK402 and it solves the problem
Posted on May 09, 2012
Can you explain in English? How to fix this problem?
Posted on Sep 10, 2010
    Genius:
  • Yamaha Master
  • 1,550 Answers
Always be the audio amplifiers IC's damaged.Good luck
Posted on Jun 05, 2008
I've got a 2005 toyota prius I replaced both battery's they were bad still nothing and then it started for a minute and shut off all indicator lights came back on
Please hook up the scanner or diagnostic computer and pull up the error codes. Nothing could be done without scanning the car. Thanks.
Feb 19, 2015 | 2005 Toyota Prius
When turning dvd on the unit shuts off right away
Pretty common with that model. All you can do is try unplugging it for 10 minutes or so and try it again. If still bad, disconnect everything hooked to it and see if it stays on. If it does, hook up one item at a time to see if a speaker or something is causing the shutdown. If it doesn't stay on with nothing hooked to it, it has internal (possibly capacitors) that are bad.
Nov 29, 2013 | JVC TH-C60 System
1987 Dodge D 50 shut off while driving, will not even turn over, battery is good
Have you checked the major fuses ?
Do you have power from the key switch down to the starter ?
Feb 25, 2013 | Cars & Trucks
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
Nothing from engine and electricals when key is turned over
Start by checking your main ground wire. and also check your main fuse, i believe it is 60amp. GL
Aug 22, 2017 | 1992 Lexus Ls 400
Sound but no picture
Hello!
Does sound comes out of TV speakers? Or you have "home theater" hooked up to?
In first occasion: TV turns on, stays on, display blinks once, then nothing?
Inverter is at fault. Second occasion: TV turns on, stays on, display glows dark, sound OK, no picture: T-con board at fault. Third occasion: TV turns on, shuts off, sound is coming through "home theater"-OK. Power supply or inverter, or T-con are at fault. TV need major diagnostics and repair in every case. Let me know if you can handle that. Will guide you through the process.
Thanks,
Alex.
Dec 15, 2011 | Toshiba Televison & Video
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Yamaha HTR-5630 Receiver Logo
328 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
