Question about Frigidaire FRS26ZSG
Refidgerator defost timer
What is the time cycle supposed to be for a fridgidaire FPGC21TA top freezer. How many hours should it take to go full cycle?
  • 3 Answers
As long as it takes for u'r camel to *** rape u!
Posted on Jun 04, 2008
Fridgidaire/Electrolux dishwasher stuck knob
It definately sounds as though the motor in the timer assembly is dying, or the gears in the assembly are wearing down to the point that the gears can't turn the way they're supposed to. Replace the timer.
Apr 17, 2012 | Frigidaire Dishwashers
Is the ge tbx19 defrost clock continious or cumulative?
The timer will advance whenever the cold control is on. (when the compressor is running, or the timer has advanced into a defrost cycle) When the refrig is cold enough (and the timer has not advanced into defrost) the timer will not be advancing. A typical defrost timer will count up 8 hours of compressor run time before going into a 30 minute defrost cycle. (the run time and defrost time can vary greatly from model to model)
Jun 16, 2010 | GE Profile 19.0 cu. ft. Top Freezer...
Bottom freezer has high temperature and is defrosting. temperature alert light is on. Tried fast freeze button and turning up the temp gages but nothing seems to be working.
as for high tempreture do u mean it is above the 0 degree normal that its supposed to be set to your freezer goes into a defrost cycel once every 6-8 hours.if your tempreture is rising on the other hand there are a couple things for you to check make sure the fan inside the freezer compartment is running.the following things you will need a meter for to measure the resistance while the power is off check the t-stat,heater to make sure there is continuity if you have continuity in both of these then you would need to check the defrost timer If you are unable to do these tests i strongly suggest you call a technician
Apr 28, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freeezer is only freezing around 26 degrees
Dirty condenser, condenser fan motor is not running, freezer overpacked, bad thermostat, evaporator ice build up and it blocks the air flow. evaporator fan motor is not running or sealed system problem.
Mar 14, 2010 | Freezers
My top freezer refridgerator PTB1953GR freezer stopped working the rest of the fridge has gone warm also. fan in freezer still working
Sounds like the overload/relay plugged onto the compressor is bad . Easily replaceable . Pt # 12002782 . Remove the back panel and disconnect from electrical outlet . On the compressor itself , this piece had 3 wires going to it .
Aug 30, 2009 | Refrigerators
Freezer working but not colder enough to freeze.
It will usually take 24 hours for the fridge/freezer to adjust fully to the temperature settings.
It is also possible that the defrost timer cycle was going into or just coming out of the defrost cycle, thus it could have delayed the start of the cooling cycle, so give it a little time to determine if the freezer is working.
If, not freezing after 24 hours, let us know and we'll go from there.
It takes longer for an empty freezer to get and hold temperatures, so it is always a good idea to have the freezer loaded with bread (thirft store bargains are cheap) or jugs of 3/4 full water (water takes longer to freeze than bread thou).
Hope you find this very helpful and best regards!
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Light works - that's it! Just quit working.
All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Your case may however be the exception, as it seems likely that the timer quit during a defrost cycle. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is not running, give the shaft a slow twist until a click is heard. The compressor should start. If it does, check the fridge in 12 hours to make sure it is not stopped again. Sometimes the nudge will make the timer run for a while. You will need to get a replacement timer. If that doesn't make it take off you should call a servicer.
May 20, 2009 | Kenmore 64802 Top Freezer Refrigerator
GE PROFILE FREEZER FAN STAYS OFF TOO LONG..ITEMS DEFROSTING
The fan stops during the whole defrost cycle, there is a bi metal control that determines the length of time the heater stays on. This could be the problem, if the heater stays on for the time that is allowed by the defrost timer it will get too warm in the freezer. the bi metal is located on the evaporator.
Feb 01, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
We have a side by side with water and ice maker in door the freezer side isnt making ice the icemaker is covered in ice i defrosted it and it is iced over again
your defost timer needs to be replace your fridge should defrost every 6 to 8 hours replace the timer cost about 20.00 thanks from gilles
Jan 09, 2009 | GE GSS20IEP Side by Side Refrigerator
Not cool
By any chance is the ticking sound coming from the defrost timer, down in the freezer compartment? If the timer isn't advancing, either there won't be any automatic defrosting and the evaporator will turn into an iceberg or (if the timer gets stuck in permanent defrost) the compressor won't come on.
Defrost timers have a knob (sort of) that you can turn with a screwdriver (in one direction only). That allows you to move the timer in and out of defrost mode for troubleshooting. You can also mark the knob with a Sharpie and watch for the mark to move. These timers are supposed to make a revolution in 6 or 8 hours, depending on the model.The defrost part of the cycle usually lasts less than half an hour.
The defrost timer isn't the only part that can fail and prevent defrosting, but it's the only one likely to tick.
Jul 30, 2008 | Avanti FF1101W Top Freezer Refrigerator
Refrigerators Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
