Copy counter in the Workcenter 45
Where is the copy counter in the Workcenter Pro 45
    President:
  • 2,072 Answers
  1. Press the [Machine Status] button on the Control Panel (the bottom button of the three to the right of the display).
  2. Select the [Machine Information] tab on the Touch Screen.
  3. Select the [Billing Counters] button. The following counters will be displayed, depending on machine configuration:
    NOTE: C13 (Total Marked images) will in general be greater than C1 + C2, or C4 + C5. C13 is incremented whenever an image is created, and will include counts of internal test patterns and reports. The other counters are not incremented when these system images are created.
Posted on Jun 05, 2008
Xerox 6505 printer
lunch the cleaning function from your device utilities.
Apr 06, 2016 | Xerox WORKCENTER 6505N COLOR LASER MFP,...
Xerox 4150 hard disk problem
First off you can only use a hard drive intended for the copier. Also when you put in the new one you will need the firmware fro the copier. THis has to come from Xerox. If you ordered the HHD from them it may already have it on them.
Nov 05, 2012 | Xerox 4150/XF WorkCentre Multifunction,...
WHEN I TURN ON THE COPIER RICOH FT 4822 AN E-5 CODE APPEARS
When a service call condition occurs, SC codes are displayed in the copy
counter. The first three digits are displayed in the copy counter. Hold down
the "·" key to display the last two digits.
Example:
When the copier detects the E507 condition, "E-5" is displayed in the copy
counter. Hold down the "·" key, and "07" is displayed in the copy counter.
Jan 28, 2011 | Office Equipment & Supplies
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
My xerox workcenter 416s has the following error: close offset cover. What is this??
There is a small cover where your paper exits into the tray. It probably is just ajar and not actuating the switch. Check in the area above the right side where you would clear a jam and where the already made copy comes out. Something there is not closed all the way, or the interlock switch has popped out.
Jan 06, 2010 | Xerox WorkCentre Pro 416SI All-In-One...
Savin 9940DP ''Set Key Counter''
Key counters are used when a copy machine is set up for public use where copies are charged on a per copy basis. Key counters look like small boxes that plug into the side of the machine and they have a counter on them that looks like a cars odometer. A user plugs in the key counter, makes copies and then takes the counter to a register to pay for the copies they made. Sounds like that is what you have going on.
Nov 02, 2009 | Savin Office Equipment & Supplies
Soft copy of the printer
The guides can be located at Xerox.com under documentation. They can be downloaded easily
Jun 03, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
115 people viewed this question
jasbo
jasbo
